[ROM] Android Open Kang Project- Jelly Bean Style
is anyone have data connectivity problems? running build 4 with franco's m5 and sometimes i have to toggle data off and back on to get it to connect to 3g/4g
Oh oh.... I had leankernel when that happened to me.
You're not the only one. I get the grey bars and have to toggle airplane mode to get back data. This has happened to me on stock AOKP and stock JellyBro.
Yes I'm on Franco M5 and AOKP build 4. Build 3 was worse about it but 4 still has it happen rarely. Seems to happen the most when driving and moving between towers frequently.
is this a rom,kernel, or radio problem? i dont seem to remember having this problem with v1 or v3 with franco's m5. would flashing the new radios help at all?
For those having issues with battery life on the stock kernel, I would suggest trying out franco or lean kernel. Either one should provide a huge improvement in battery life. It did for me.
When is job build 5 going to drop? It is mentioned on Sundays going forward.
They typically announce a Sunday build on Twitter on Thursday. If you don't hear anything on Thursday, chances are there is no build coming out that following Sunday.
My most recent build went up on sunday instead =]
Lol.
Lockscreen targets and NavBar widgets included...
Cherries and Stems.
The navbar widgets hadn't been touched in quite some time...
So they needed a hefty rebasing...but I've managed to get them in with full functionality.
I haven't tested much (I only use google play widget) but they seem stable on my end.
Anyone having problems with Pandora? Any time I open the app it will FC. I have to uninstall and reinstall to get it to work. Next time I go to use it the same thing happens
I don't use Pandora much, but just checked and I have the same FC issue. I haven?t tried to uninstall/reinstall yet.
Mine plays fine. Am on WiFi, logged on and picked a station its started fine and played a couple of songs. No issues here...
Same here no issued with Pandora.
I didn?t notice until I flashed Franco r283.
Sent from my Island using my Smoke Monster
Pandora works today.. Weird
I get Grey bars randomly. Usually when i turn on wifi. A quick toggle of airplane mode usually fixes it
Most ROMs give you random grey bars. It usually goes back to blue in a matter of a couple of seconds.
Brought to you by the Google Galaxy Nexus. It IS better than the iPhone 5.
AnDevCon December 4-7 2012 in San Fran!
briefcasejoe443
