[ROM] Android Open Kang Project- Jelly Bean Style
ohh, thats a nightly, ok gotcha. any noticeable differences?
Took the link down.
But lock screen targets and NavWidgets.
Quick reply popup and quick emoji.
As far as differences in 4.1.2 you'll only notice one finger notification expansion.
I checked out the app for two minutes... didn't care for it, but then again, I'm an unofficial nightly flasher, so I'm usually to to date before the "official" release.
Sent from my wireless telephonic device.
Took the link down.
what is this one finger expansion everyone is talking about?
Not from me, but I asked this same in question in another thread and here is the answer I got, hopefully this is okay to link from greyhd:
Before you needed two fingers to expand the notification Window, now you only need one finger and the notification will expand. Does that make sense? Not sure how to explain.
Basically, what I didn't know was, we are currently able to expand certain notifications in the drop down menu, which would give you more information about that particular notification by expanding it down with two fingers. Now you can expand and notification within the notification menu with one finger.
currently to expand notifications in jelly bean it requires to fingers with the new 4.1.2 update you will be able to expand notifications using one finger instead of two. its a small thing but really helps with one hand operation
Sent from my ASUS Transformer Pad TF700T using Tapatalk 2
I had no idea that was even possible. Look at that, learned something new
I finally bit the bullet and installed build 4 the other day. Didn't mess with the kernel yet. So far so good, love all of the options compared to BB. Only thing I wish I could find was something to change the transparency of the status bar, short of installing a theme. Haven't found a theme I like either, but I haven't gotten tired of the ICS/JB look yet. Once I do I'll probably switch to miui anyways. No major complaints though so far.
Anyone want an AOKP 4.1.2 Build?
Edit:
Well...
No response.
It's all for me then lol.
Lockscreen targets.
Quick emoji.
Quick reply popup.
NavWidgets.
TabletUI custom NavBar.
Again, I'm done providing these to the public.
Figured a bump in Android Version was enough to merit a post.
Pretty please post this release again? Wasn't able to grab it in time :(
Cherries:
Navbar widget auto-sizing fixes.
Lockscreen targets.
Quick emoji.
Quick reply pop-up.
Lockscreen Vibrate toggle.
Obviously built on 4.1.2 - anything after the 10th has been.
Edit:
Link deletion in three hours.
Edit:
Link removed.
I said I wan't even going to post these anymore...
Y'all are lucky!
Any grouper users?
Link removal soon!
Link removed.
Good day, sirs.
anyone else's GNex getting really hot with poor battery life? i am on B3 and franco? was running r283, but ive switched to a stable leankernel to see how that helps.... the improvement is only marginal so i would attribute it more to the rom
I'm on the same configuration (B3/r283) and am not having any heat or battery issues.
Where is the gmail sync setting, I remember if I went to setting, and personal there was a accounts and sync, can not find it now. running AOKP B4. I have been not getting all the emails to my phone but if I go to the gmail on my pc there are emails that were never delivered to my phone. want to try to turn sync on and off to see what happens. I have tried to send myself "test" emails and everyone makes it don't understand it.
Had some users on Rootz crying about the lockscreen before secure unlock being missing...
So I made them a present...
That being said, the present (I don't think this is my fault) doesn't seem to work completely...in that it doesn't open any targets.
It'll just show the unlock ring, then your secure lock. And no matter what you select it simply unlocks.
The commit is ancient...I think it needs to be completely rewritten at this point.
Other than that...build is solid from what I can tell.
So if you don't mind a completely new feature not working as intended, flash away.
I'm a liar. Works fine!
_______________________________________________________________
All this is included in this build:
Merged Gerrit
Along with:
Landscape Lockscreen Target Fix
More Long-Press Targets on Keyboard
Quick Reply Pop-up
Lockscreen Vibrate
Torch Toggle Fix
Ram Bar in Recents Menu
Show Lockscreen Before Secure Unlock
Y'all better love this ****.
Took me ages to rebase correctly.
And I don't even use a secure lock <_<.
That being said; there was a lot of actual code that needed rebasing. I'm not a developer.
Who knows what I did in there =]
I HIGHLY recommend you backup your current set-up.
I HIGHLY recommend you wipe before flashing.
Download:
TORO ONLY
Merged Gerrit
Along with:
Quick Reply Pop-up
Lockscreen Vibrate
Torch Toggle Fix
Download:
TORO ONLY
Will grab it during lunch, thanks :)
Riyan75
