[ROM][AOSP][10/31][JB] Bugless Beast VZW Galaxy Nexus
Re: [ROM][AOSP][8/7][JB] Bugless Beast VZW Galaxy Nexus
First time ROM'er here and I went with BB for my first outing. I have a quick question though regarding the process.
I did a wipre data/factory and a wipe Dalvik Cache. I then did the install zip from sdcard. Everything went well and when I booted in all my data was still there, sure the apps were gone but the data was intact. Is this what I should be expecting to see?
Thanks.
(BTW, the limited playing I have done with BB so far is sweet1!)
Thanks.
Define data. If you signed into you Google account, stuff like contacts show up due to sync.
Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
My pictures and music was still intact.
That's on your SDcard, which is not wiped unless you purposefully wipe it or lock/unlock the bootloader.
So i just flashed this ROM right now and noticed there aren't any GAPPS? Could somebody help. Also my installed apps are not restoring from my google account. Can somebody also help with this? THanks!
There should be. Is there a play store? If so it has gapps. Go there and start downloading :)
Sent from my Nexus 7 using Xparent Cyan Tapatalk 2
Gapps are in there...
Okay well i downloaded the GAPPS. Thanks! Also can you explain to me why my google account isnt reinstalling the apps that i had installed before? I know when i was on vicious jb it automatically restored my apps. Could you help calrify this issue?
Did you tell it to restore the apps after you reinstalled and ran through the setup process?
It's a check box...
I never use that feature because I've found tibu works better and restores the app data too something Google play doesn't restore...
Okay. So i wiped my phone again to see if i could fix it. It worked! Also this is a great ROM!
does bb come with any themes? kinda of a noob......
My phone stopped accepting a charge through my wall charger. USB charging works. Anyone else experiencing this?
That's not a Bugless issue. I've had the same thing happen on my tfp (doesn't run bugless). I just unplugged it from the wall for a few min and rebooted the tablet to fix it. It's also possible that a surge hit the wall charger and it blew.
As it turns out, USB is basically acting up too - it works once after reboot. If unplugged and plugged back in, it will not charge. So weird. I'm sure you're right, probably not a BB issue, but I just thought I'd throw it out there...
dev90
