[ROM][AOSP][4.0.3] Codename Android 1.5.5 [Full Open Source]
Re: [ROM][AOSP][4.0.3] Codename Android 1.2.0 [Full Open Source]
Do you happen to know what kernel was used for 1.14? That was stellar, this new one is ok so far.
I think it was Imo's or it was based off Imo's but I could be thinking of an earlier version... in any case its outdated, Imo updates his kernel pretty frequently ([kernel] Leankernel: Minimalistic Kernel (1.7.1, 1/20/12) - RootzWiki), you have no reason to want to run a kernel from a week ago on this phone when they are all being updated so often, lol, with tweaks and bugfixes and improved functionality.
I liked Imo's kernels but stopped running them a few weeks ago as they tended to stutter on heavy gaming/processes. I saw the best performance and battery life with Franco's nightlies (13.1 is the most recent, [KERNEL][GPL][20 JAN - #13.1] franco.Kernel | 4.0.3 | OC | UV | INIT.D | COLORCONTROL - xda-developers
Also I think the Trinity kernel gave me even better performance but sacrificed a bit a battery life, however in the last day or so I think it was updated with a fix for the battery drain, so it might be the way to go now: http://www.derkernel.com/
Like I said, there are MANY options all of which are updated very often.. no easy answer for you, lol.
Anybody else having issues with apps starting, then closing suddenly? No force closes either. The one that keeps crashing for me is Angry Birds. Tried two versions, both did same thing.
Superuser stops working through rom manager when trying to boot into recovery, but it continues to boot anyway.
Any ideas on that?
Google Music did it to me once today.
Any ideas on that?
I got the same Superuser message but ignored it. I tried changing the governor to hotplug and the phone froze. Had to do a battery pull. On reboot the governor had gone back to the default, so I just left it. Anyone know where I can find a description of the governors?
I can't get haxsync to sync my contacts like stock Rom only syncs like 2 contacts any ideas anybody
Never mind got it to work like the little customization on this ROM
I love this from but I really want aosp tethering. Is there any way to get it to work? I switched to gummy nex but I'm not a huge fan. Its not a deal breaker at the moment but I really want the pure Google experience like my n1. Anyone with a suggestion or a similar from with aosp would be much appreciated
Wifi tether updated for ics...
http://db.tt/q2sAvZtF
I appreciate your input but you didn't read what I'm looking for. I want to use the tethering option on the phone like in other roms and like a pure Google phone. I don't want to use a third party app. Sorry if I wasn't entirely clear about that. I love this rom like my first born but that's all that's missing. I know its possible though because I'm on gummy nex right now and it works. I just don't like how I can't edit the pull down quick settings like in codenames from and the lock screen on this rom stinks.
That feature works on AOKP. (android open kang project)
Sent this with it.
Once again not reading what I'm asking. I know of many other roms that have this. I am asking if anyone knows how to make it work for THIS ROM WITH NO 3rd party app. Sorry to be getting slightly annoyed and I understand that your just trying to be helpful but Im asking a specific question. If you don't have an answer please let someone see it who does. To be clear I want to know if I can make tethering IN THE ANDROID MENU work. Anyone with some help please let me know. I'm going to check out kang though maybe I'll like it.
WiFi hotspot works for me.
um. what exactly did i not read?
aokp = an aosp rom, similar to codename, in which built in hotspot works.
anyway aokp is good. i havent flashed codename but they are both option-rich, and i would recommend aokp for sure.
gl.
Its been done on stock Verizon tethering without paying for the option. Do a search.
Right from the hotspot menu? It works for me too and says it connected but it doesn't transfer any data. I was tethering ito an touch to test and it worked with gummy but not codename. I'll try Lang tomorrow
Also I'm losing charge while I'm using my phone and its plugged in?
Yes. I my last reply was from my HP Touchpad using the hotspot and this reply is from my Laptop (Lubuntu OS) connected to the hotspot. WEP works too. It worked for me with all versions of this ROM and I don't have a tethering plan with Verizon.
My home button is not working. Back and Recent programs buttons work. Any ideas?
Not sure if your using Nova Launcher but in the behavior settings there are some changes you can make for the home key. If not I'm sure a restart would fix it.
elowen89
