[ROM][AOSP] ICS Nexus S 4G Source ROM Port
Just installed and I dont see superuser and I can't use titanium so I know its not rooted. Do I have to adb root this bad boy because i'm loving it so far though its a WIP
thats strange, i'm still rooted with superuser after flashing. the developer has it listed as being as rooted, and android central says the same thing in their hands on. did you do a full wipe, plus cache and davlik when you installed in?
Reactions: Loco Wit The Pre
Sure did. I also installed SU via clockwork... thats probably the issue. Only reason I want SU is wifi tether, can't hop on xbox live without it :D
UPDATE: YEP that was the problem... I feel dumb but now i've decided to make this my daily. FACE LOCK get ready iphone brats at work :cool:
been running this all day. Awesome.
I love the new camera...it's fast and panorama is actually pretty awesome.
The new keyboard is amazingly fast, I prefer it to swift x.
Just need a custom kernel that I can overclock, maybe bln and voodoo also and i'll be all set!
So, I have Beezy's 3.6 ICS ROM currently on my phone and have had just a few issues with it, though for the most part it works great. Do you recommend I change to this mod?
Beezy's port was great but I think this runs a little better...feels more refined and it should be since it's built from src and not the sdk
Yes! Switch! Beezy's ROM is an sdk port. This is REAL ICS.
This is AWESOME. I was running Beezy's who built his from the SDK port (and ran fantastically) but this has working bluetooth and an easy fix for Wi-Fi (just use the fix supplied in the post) !!!! Thank all the devs for all the work they have done with Android throughout the years!
Ezekeel has released his glados kernel for this rom. Still WIP but mostly fully functional. I can confirm bld and bln. Setcpu won't OC , but lazy is available. Deep idle might not work but I can't report either way. Nstools gives access to all mods. Voodoo works as does changing voltages using setcpu.
http://forum.xda-developers.com/showthread.php?t=1355980
Edit**** so I'm a dolt......set the live oc value to oc......
Long days and pleasant nights............
Reactions: lightyear420
I don't understand the facial recognition complaints. I have a bushy goatee and while it's not 100% for me, it does do a good job recognizing my face. I just can't get a close-up. I've gotta hold my phone at almost a full arm's length to get it to work right.
so the only issue i have is wifi signal not showing up in the status bar and the inability to recieve MMS.
NS4G here.
@shocktherapy try using go sms app instead of stock.And for the wifi there is a fix zip for it
first of all, this port looks and runs really, really well, and i can't imagine the work that went into making this happen.
before taking the plunge (i was unrooted beforehand) i ran MyBackup and pulled my contacts, SMSs, apps, etc. to the internal storage. i moved them to my hard drive and let the One-Click-Root application do the work. it was working great until i decided to push everything back with MyBackup, which i really shouldn't have done. my contacts were already in there and i didnt exactly NEED all my texts.
anyway, now that it's trying to do this, the Messaging app is hanging and FCing due to the 5000 or so unreads it thinks i have, and i'm getting a "Too Many Contacts Deletes" notification up top. i'm a little too wary to let it all delete, lest i end up losing everything on Google's end. also, my Contacts app seems to have disappeared. did anyone go through this too?
looks like v2 is about to hit
change log
Changes in v2
- Optimized binaries (user build)
- wpa_supplicant switched to 0.8, should fix status icon and hopefully more
- Tethering over wifi and usb
- USB mass storage
- Data usage statistics
- Updated Maps, Music and Google+
- Updated kernel to support usb, statistics and wifi tethering
- Note: Camera icon on home screen is not working, remove it and add it again
it's up for the GSM version, right now the NS4G is "building"
change log
Changes in v2
- USB mass storage
Good stuff digitalslacker... Thanks for keeping everyone in the loop :)
On a side note, bet your just itchin to get your hands on that IOU Galaxy Nexus aren't you...
Couple of things, hopefully you all can help me out. First off, this ROM is great, thanks for the hard work.
I can't successfully add Facebook to my accounts to sync, and I can't uninstall Music app to get the new non beta Google music app. Thanks in advance for any guidance!!
hmm...I have installed this, and when I plug my phone in to my computer, I can't seem to get USB storage to show up at all. I need to get that wifi patch on my phone...am I missing something?
USB storage was broke on the NS4G Rom, wait for the next update and you will have to download the new version directly from your phone.
V2 fixes the USB storage issues and also a few other fixes. Google Wallet is not there and it may be a while before 4g will be active on this ROM.
Reactions: carysb7478
handsome
