[ROM][CM10][JB] Euroskank JellyBro
Where is everyone downloading themes from?
I posted the same question and someone directed me to xda. Scroll back a few pages or search for cm10 in the Android development - themes section in xda.
Here you go :
http://forum.xda-developers.com/showthread.php?t=1801752
Side note, just had a random reboot from the 815 build.
Reactions: Akuma
Here you go :
Yep, several random reboots as well from the 8-15 build
Sent from my toaster (rooted).
Yea, the 8-15 build is definitely broken for me. First one that has acted like this and i always flash the nightlies. I have taken all of the standard steps to try and fix.... Wipe, permissions, etc
Running Franco 240
-Constant random reboots
-Stock gallery only shows new pics, not the 600 that quickpic STILL shows.
-overall sluggishness
I may still it out until the next nightly or go back to 8-14 which seemed flawless.
Running Franco 240
I am not seeing any of these issues. I am not using a different kernel. Maybe that's the difference.
Sent from my Galaxy Nexus
Running Franco 240
No problem here as well. I have read ROM manager update may be responsible for some issues. I can't say for sure. Look for .nomedia file on your SD card. If there delete it.
I didn't realize that RomManager was cooked into this rom. If I use TWRP, can I just use TitBack(lol) to remove it?
I don't believe that it is. That was just a suggestion for those that do use ROM manager. Perhaps this is not related to your problem.
That's odd. It would only let me uninstall the updates, as if it was part of the system applications. Titanium backup also shows it in red, as if it is a stock application. Hhmmm
In Tibu select ROM manager. One of the options is convert to app. Then uninstall.
After the 0815 issues (battery drain and no photos) I think I'm done with nightlies for now. I'll check back and see here to see whether a nightly is worthwhile before downloading.
Reactions: KillerQ
It's been affecting pretty much every rom FWIW, not just these :)
Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
I haven't had any issues on 815, but something needs to happen for better battery life. Maybe I need to stop flashing every single update and let it settle?
Sent from a gelatinous form of nexus
Reactions: KillerQ
My battery life has been pretty good, but had 1 random reboot with the stock kernel. I will go ahead and download the latest one.
Battery has been pretty weak sauce since last night, but I'll give it time to settle. But LED Notifications no longer work...any ideas what I may or may not have done to cause this? Ran through my settings, etc, all seems as it should be.
Or you can flash the 8/16 build that went up. ;)
Sent from my SGSIII
Damn. Ok, I'll bite.
But will it get me back the thousands of photos that disappeared with 0815? I can see them on G+, I just don't know how to get them onto the phone again.
Never thought of using My Backup Pro to backup and restore my home screens!
Will it backup all screens, including widgets and then restore all? Folders and all? What happens if an app is not installed on a home screen restore?
This would save me a time if time! I am not to interested in loading other launchers to do this.
Transmitted from a banned Galaxy Nexus LTE running Jellybro CM10 kang using Tapatalk 2
If you choose for it to back up system settings and Android Home (I think that's what it's called) it will bring the information to your new rom. I love it. Wish I would have found out about it sooner. What do you mean by what happens if an app is not installed on a home screen restore?
try reflash? im running 8/15 nightly with 7/23 gapps and franco r241, LED works.
Reactions: lpt2569
I have been flashing since the first release of this Rom, and updated this morning, but Gallery only seems to show folder with PNG files, will not display any other picture formats. Any ideas about a fix for this?
Dgeeksldugen
