[ROM][CM10][JB] Euroskank JellyBro
I did a quickie clean install, but I used TiBu to restore apps and system so I didn't have to monkey with everything to get my setup back. Still feels a little choppy.
Noticed that my wireless/data signal seems to be staying gray. No big deal.
Liquid,
There's a known issue when you use TiBu to restore SYSTEM apps. When you do that, your signal bars will never turn blue properly. You can only restore non-system apps to get it working normally.
Hope this helps,
Matt!
Sent from my toaster (rooted).
Liquid,
Hope this helps,
Matt!
Good to know! Thanks!
edit: I reflashed totally clean without system apps in backup. That seems to have fixed my issues.
Reactions: KillerQ
Anyone else notice the system settings FC whenever you are setting up a new keyboard from that keyboard's setup wizard when it tries to allow you to enable said keyboard?
Did that make sense?
Yes, I had that issue when trying to re-install Swype.
Yes I have the same issue and I sent a message to fitsnugly about the issue.
Looks like new radios have been leaked. Anyone update yet?
I updated the radios. Can't tell a difference yet, but I haven't left my office building since I flashed them (I'm on WiFi at work).
Radios are usually never included with roms. If they are, it's a separate flashable zip 99% of the time.
If you want the new radios, check the radios thread/guide :).
Just flashed the new radios, will report back in a little bit with results.
Also this ROM has awesome battery life with the stock kernel and the 2100 mAh battery
This was with pretty heavy usage, and the only time during the day I charged it was for about 20 minutes when I got home from school.
HAH.... I don't know how you guys do that. I have trouble getting that with a 3800 mAh battery
Same here but I'm using the 2100 battery.
Seems like I always come back to this ROM. AOKP seemed to cause random restarts and it was getting to annoying.
Transmitted by the Google Galaxy Nexus. Jellyfied!
Reactions: KillerQ
For those that are running themes, do you need to switch back to the default theme before dirty flashing? Or does that not matter at all.
Just did a clean install of 0829 on my gnex, stock kernel, fits gapps and tbu restore of some apps. All running well so far!
Click to view quoted image
I haven't had a chance to use it, but overnight I still had 90% of battery left when before it was well under 80%. This Rom and stock kernel are great.
Side note, looks like 830 is up with torch and tap updates(Link from 1st Post-Changelog on right side).
Reactions: KillerQ
I'm surprised that the new featured saut?ed into the nightlies are not more widely advertised. The recent torch addition, for example... It's features like that that cause people to hop over from other ROMS. Just my $0.09
Thanks,
Matt!
Thanks,
Matt!
I'm surprised as well. The rom is as stable as others with great customization , but I think it comes down to preference.
Reactions: KillerQ
Yep. I jumped on CNA because it had the features I like and it's been stable. ES was my DD for a while and I keep checking in but I can't tell if it has a few of the features I want without flashing. ES is now my fall back option and I won't bother flashing unless I need to. (Or I need a crackflash fix. LOL )
hincapie
