[ROM][CM9][ICS][4.0.4] Cyanogenmod 9, Android ICS 4.0.4
Maybe try putting govonor in kernel settings to smartassv2 when you flashed all this dd you wipe data,cache and daviik ?
Yes, in ROM manager, while selecting flash ROM from SD card, I always do the pre-installation steps wipe data/factory reset and wipe cache partition.
By the way I greatly appreciate you trying to help me! Thank you!
There's the problem. There are issues using Rom Manager to flash ROMs only use it for flashing a recovery. The best way is thru your CWM Recovery.
Flashed it again through CWM, still the same result :( Why am I the only one getting this? The screen just freezes when I'm just moving through the apps. Sometimes it takes time to load but most of the time it just freezes off with the current screen and I have to remove the battery, go to CWM Recovery and reboot from there. If I try to power on normally from the power button, it doesn't boot. It starts to show as if it's charging for a couple of seconds and then switches off.
I guess it is just too slow for my phone. But why is that so?
The normal booting doesn't work for thus rom (it's a boot bug). Normally you go into cwm and reboot into the phone.
Sent from my LG-p505 using Tapatalk 2
Anyone else having problems flashing the latest (8-11) weekly?
Sent from my LG-p505 using Android Central Forums
i've been away from this forum too much time, i was one of the first guys helping arjen with logs and stuff like that... and now we have an almost fully working ics on our phones, it was kinda fast how things around here evolve o:... just to say that im back here to test any new thing we got and to send feedback or what we need... i have a lg thrive and im currently on the latest weekly cm-9-20120811-UNOFFICIAL-p505.zip... so answering to Eqbirvin, no, i had no trouble installing it o:
Well welcome back! haha i know it has made a lot of people happy too.
hmmmm okay, its probably the recovery im using. Thank you! :)
Sent from my Transformer Prime TF201 using Android Central Forums
Can I use a Bluetooth headset for hands free calling with this ROM? I know it says it doesn't work on the first post, but has it been fixed since then?
How do you partition the sd card?
You must have a custom recovery installed first.
Make a backup of your SDCard as partitioning it WILL ERASE ALL DATA.
Reboot device into recovery. Instructions for CWM follow...
Choose the 'Advanced' option
Choose 'Partition SDCard'
Follow the prompts.
Power off device.
Restore data to SDCard.
Reboot device.
Good luck!:)
Hey bill, do you have Google talk or Skype? I want to be able contact you quickly for help if you don't mind! :D
Sent from my LG-P500 using Tapatalk 2
Sorry, no I don't. I'm really not online a lot.
Sent from my LG-P506 using Android Central Forums
Tried flashing the 8/11 rom and immediately threw a (status 7) error because of the recovery some of us are using. I repackaged it with bill weckles modified updater script as his instructions stated and it worked fine. Remember, this is just for people with a CWM that doesn't allow you to flash roms for other phones. Easy instructions found on the first post of this page. http://forums.androidcentral.com/t-lg-phoenix-thrive/189546-rom-ics-4-0-4-piccolo-2.html
Great ROM and thanks for sharing...I tried this ROM and few others (from XDA) but i am still getting the same bug,,,i cant record video with the camera...
I always follow the steps of clean/wipe/format and i have CWM installed...I install the ROM(latest 08122012) and Gapps...No new or old BB as its already in the ROM...
Any help? or can some check and see if this camera rocorder is acting up...
Thanks
Thanks
Im pretty sure the camera issue you are having is tied into the lack of OpenMax Support by Qualcomm. So far there has been no fix for the openmax issue If you want a 100% functional ROM you will have to go with one of the Gingerbread based ROMs. There have been a number petitions and requests made but so far nothing has happened other than Qualcomm saying it isnt supported.
Reactions: Thrivy
donavan, thanks...for a second i thought i was doing something wrong...ok so there is no support for the CamRec...
I'll be switching back to GB,,,
pamatika
