[ROM][CM9][ICS][4.0.4] Cyanogenmod 9, Android ICS 4.0.4
You install Piccolo the same way you do any rom. if you want to go back to 2.3 I would recommend going to the (semi)perfectly working CM7. Im using it on mine no issues at all.
Hi,
Is there still problem with these:
- Wifi tethering, Offline charging: needs usb driver update from 3.0 kernel
- FM Radio: not implemented in CM yet
- Youtube HQ: needs OpenMaX(omx) libraries for armv6
- Bluetooth headset
I don't mind the youtube thing but the others are important for me.
If there is a way to fix them please let me know.
Thank you.
bukablokiratmpaninmobile
