[ROM-CM9]Paranoid Android Tablet UI~August 15th,2012 MIC FIXED
I minimized the ringtones selection by ALOT, do you have them selected?
The status bar is like that because of the DPI. If you change to MDPI, everything will centered. :)
I actually do have a ringtone selected. It only happened the first time
And about the offset, I was playing with the hybrid settings in the paranoid menu and I made everything MDPI thanks c: this is the first time using another rom besides mirage as my daily. Tbh.
I loved it :)
Only prob was when I changed dpi to 80 I got status bar (yay) but when I unlock my phone keeps rebooting
Sent from my LG-LS670 using Tapatalk 2
System DPI.
So you can confirm MMS? :D
And is your keyboard working properly?
Re: [ROM-CM9]Paranoid Android Tablet UI~August 15th,2012 MIC FIXE
System DPI.
thanks :D
I confirm MMS receiving :DD I'm trying mms sending. It's taking a while to send tbh, if it's sending at all.
Default android keyboard working great. Swiftkey, not so much. Keep getting Trial ended error message and prediction isn't working.
There's one problem I can't fix :/ (look at the attached image)
EDIT: MMS not sending :( and you should add a 'how to get bottom status bar' to OP
DPI issues. :(
Our phone is so tiny, reasons why it don't work xD
MMS takes forever to send on ICS.
DPI issues. :(
I can live with DPI issues. but MMS still says 'sending'. ICS is slow at sending mms but I doubt it takes an hour xD
MMS always took forever for me. Try resending. I usually click Edit and send.
Just flashed this and now messing with it.This rom is awesome! Please never stop working on this, its very pleasing to my eyes and my fingers, lol.
I can't fine how to change the keyboard dpi I can't find list view apps
Follow the instructions at boot. I recommend disabling Hybrid Mode until you change the DPI of keyboard. You have the schroll from
Download Running All
To the All part.
I don't know what to do with the .rle file. Idk how to unpack a boot image and that stuff. :o
To the All part.
i nevered disabled hybrid... mabey thats why i had troubles... rom always froze when changing dpi's to 160 when prompt to reboot popped up... same deal when trying to use playstore via app drawer... always froze when prompred to accept agreement... tried both apks... never could get playstore to work... couldnt find all or running in settings>applications... only downloaded and on sdcard...
Do you have a Linux VM? dsixda's android kitchen supports unpacking/repacking boot images.
Sent from my LG-LS670 using Android Central Forums
Did you overclock it?
I have no idea what your talking about :(
Reactions: Encerspay45
Ubuntu & dsixda's Android Kitchen from xda-developers is all you need for unpacking the boot.img. I don't have the link or the time right now to guide you through unpacking. But virtualbox will allow you to run Ubuntu while running Windows.
mohamsn
