[ROM-CM9]Paranoid Android Tablet UI~August 15th,2012 MIC FIXED
Let me know if you need a tester lurkin, ill be glad to. I already told Cole ;)
Sent from my VM670 using Tapatalk
New Build is out!
Download: Paranoid Android 8-15-12 TGL.zip
Changelog:
- Synced with Beta2 Quattriumus
- Paranoid Settings fixed
- MMS still working, hopefully. My bill JUST JUST died.
- Mic is fixed!!!! You can now do phone calls :)
- Minor stuff
- Added Swift Key, made for Paranoid.
NEW INSTRUCTIONS!!!!!!
1. Wipe EVERYTHING
2. Flash Rom
3. Flash any tweaks, if you want
4. Boot up the Rom
5 Once the Rom is booted, Paranoid Settings, And DISABLE Hybrid Mode.
6. Reboot the phone!
7. Go back into Paranoid settings and Enable Hybrid setting
8. Go to List view apps( I believe it was called that)
9. Go to all, And change the DPI of Android Keyboard, And Swift Key beta to 160 by going to Custom DPI
10. Reboot, and Enjoy! :D
I will be posting pictures of how to do this in a few.
First go here.
Click to view quoted image
Edit the DPI stuff to look like thisClick to view quoted image
Reboot and you should have this Click to view quoted image
I personally don't like jellybean. Not sure why though.
Thanks lurkin for making it just about fully functional
1 question
Does it have bottom status bar :p
Sent from my LG-LS670 using Tapatalk 2
1 question
Change DPI to 80 AFTER following the instructions.
Can any confirm MMS
Re: [ROM-CM9]Paranoid Android Tablet UI~August 15th,2012 MIC FIXE
after i get on the android keyboard app how do i change the dpi settings?!?!?!?!? thats the only thing i need to do please help!!!!!!!!!!:(
Go here
Go to all, and select the keyboard you want to MDPI
And reboot to have
Although it doesn't seem much different than ics, it seems to perform fairly well.
I am stable at 480MHz(just realized earlier today that I've been running powersave@480 for more than a week). Usually I'd have to overclock to 806-864 to be as stable and smooth as jellybean is.
Although it is still in early alpha stage, it seems to be a lot more stable than ICS currently is.
sent from my Zom-"Bean'(CM10 JellyBean).
This is really going to put a damper on my productivity at work tomorrow!Keep up the good work!!!!
Idk how to use that, but i didnt affect anything. Quattriumus stuff should still be in there.
It is located in system/etc/init.d, so if you removed that folder, it wont be there. Idk if you did though
Can I just put a request in? App2ext.
Sent from my LG-LS670 using Android Central Forums
Im using on of these scripts right now on the gingersnap rom... i juss flashed it after i flashed the rom... it works
http://forum.xda-developers.com/showthread.php?t=1716124
I've pretty much bailed on my OV since I got an Infuse 4G. I've been running Paranoid Android on that, and despite my general distaste for ICS, I've loved it. We just got a JB version of PA released tonight, so I'm probably gonna give that a shot. If I get nostalgic, I may have to load this on my OV and see how it runs.
Yeah. Its all there. :)
And V6 is also included by default. I remembered that when going through the Build.Prop
I remember you :p
Jelly Bean, i hate the UI, somewhat... Its like they stalk us on XDA and take the ideas.
I'm planning on flashing this and working on jellybean after school thanks
Ok so I can send & receive MMS, it just didn't give me a notification and it took a while but since it is MMS, i'd figured it would. Mic definitely works :D There are some offsets though. when there's an incoming call, the phone icon at the bottom is cut off. when you slide down the notification bar, the blue circle under virgin mobile is set a little too far to the right. otherwise ... this is TOO sexy.
Reactions: ThatGuyLurkin
I minimized the ringtones selection by ALOT, do you have them selected?
The status bar is like that because of the DPI. If you change to MDPI, everything will centered. :)
I remember you :p
XDA is where I've been lurking since the Infuse section is basically dead here on AC. People don't seem quite so...prick-ish as they once did over there, at least. I really can't tell much difference between ICS and JB, but oddly enough, I like JB a lot more. The face unlock is kinda neat, I guess.
It was total culture shock coming from the OV and then trying to deal with a Samsung Galaxy-class phone. With the OV, everything is so simple and fairly intuitive. With the Infuse..not so much. I was completely lost for the first week. :-[
Thank you thank you thank you, I am so flashing this.
Flashing now, i'll report back after i test mms and mic just to make sure they are working
Edit: I followed the directions to the letter but cannot send or recieve mms, it just says sending but wont do anything
Ok I can receive mms but not send. I'm also getting freezes and reboots. I still fiddling with settings though
ZackS
