[ROM-CM9]Paranoid Android Tablet UI~August 15th,2012 MIC FIXED
TGL* ;)
Ill take the current build and try to fix MMS. Ill try to release tomorrow. High School is a drag, didn't know it was like this. :p
umm easier way to fix the tiny keyboard is to open up the rom zip(keep it in a zip!!!), extract the pad.prop file. look for the line that says "com.android.inputmethod.latin.dpi=" and set it to 160 (for me its at line 62 in notepad++) then drag your modified pad.prop file into the zip. overwrite if it asks. (if you unzip and try to re zip it wont work.) also to remove swiftkey remove the apk from system/app also dont forget to remove the pad.prop entry for it. (if you forget that it wont blow up though)
I just got a couple ideas from you! I will try, but not right away. For now, I'm busy with life :P
High School!?! How old are you lol
I'm 14, freshman :P
I'm 14, freshman :P
Lol. Freshman xD. Junior here haha. Probably gonna flash this again since jb is starting to give me major battery issues :/
Sent from my Android 4.1 Jelly Bean OV.
APKtool and Winrar, you guys make it look hard but it's actually REALLY easy xD
I know there are alot of younger individuals on the forums, but I have still learned a lot from everyone that posts! Unfortunately I am old at least by age, 40. ;)
It's a huge rom, of which Ksood ports it from the Galaxy Nexus which makes files huge. So of course you will find problems :P
Lower it to 90. If it bootloops, go to 135-145.
If not, use 85
If not, use 85
Well that's cool now a solution
Flashing tomorrow and trying
Sent from my LG-LS670 using Tapatalk 2
I forgot about MMS, I'll try to re-release the build with MMS fixed. I'm waiting on reply for a new base.
pmm09
