[ROM-CM9]Paranoid Android Tablet UI~August 15th,2012 MIC FIXED
What recovery are you using? Maybe a bad download, or bad flash.
I removed 95% of the Audio Ringtones and Notifications. So I put my favorite Ringtone in. The Notification was the last one to not be deleted. With all of it, the rom was 117MB's.
I'm uploading the newer version now with fixed MMS, Root, and less MB's.
My Gosh, Mediafire takes forever to upload...... ~.~
I'll give the update a go, and report any bugs that I notice, and back to you.
Sent from my un-dead sandwich.
Re: [ROM-ICS-CM9]~~~~Paranoid Android TABLET UI~~~~
I tried Cannibal and it didnt work. Im gonna try updating to the latest version.
I meant Cannibal. I just updated my Cannibal and it has begun to install. Seeing whats going on now
Just finished installing. At the boot screen. Quite amazing looking if I do say so. Will check it out once boot finishes.
Kso. While messing with it, you will sometimes get this .
OMG. Boots on Optimus S and it looks so sexy. I love it!
Just got done attempting to talk on my ov, and the mic isn't programed correctly or something. It's not picking up my voice.
Reactions: ThatGuyLurkin
EDIT: It works! Im just so impatient. I really cant wait for the next update for the keyboard fix!
It takes a whiles to install but just leave it. Took mine like 10 mins. :)
It has an ffffffing screensaver!
home button doesn't work, nothing really works. the text is readable, so i'd love to see everything working. i'd use it as a daily.
On the Optimus S, all buttons work. Home and menu just need to be switched because o this phones button layout.
Yes! You just reminded me!!!
In phone calls do not work! You can hear them, but they can't hear you. Need some help fixing that! :o
On Optimus v all of the buttons work too. Maybe you had a bad flash?
I will be using this as my nightly ROM (until calling gets fixed)
(doubt it but.....) Some of the bugs could be caused by the porting process... Just a thought.
Im thinking Media files, or Phone.apk
cinemacritic
