[ROM-CM9]Paranoid Android Tablet UI~August 15th,2012 MIC FIXED
Re: [ROM-ICS-CM9]~~~~Paranoid Android TABLET UI~~~~June 27
it would be cool to have the bottom status bar but the rom is very cool ;)
I've been running into memory trouble on my SD (I have to stock 2gb one lol) once I get that cleared up I'll flash and test!
Sent from my AT100 using Tapatalk 2
Everything's perfect for me so far except:
Mic during calls
YouTube SD choppy, no HD
Paranoid Settings force closing
Fix the mic and I could live! Thanks for the port!
could you please upload it to another host? Mediafire always gives me problems
I read in the op we don't need gapps? Is that true?
Edit: I found that u can't use pattern. It doesn't allow u to press next.
Mic during calls
Same bugs as CM9, and im not a dev. Not that easy.
Use Opera Mobile.
Turn phone landscape to click next.
Mix fix and I'll download it thanks.
Maybe you could help then...? No idea what causes it
Sent from my Motorola Triumph using Tapatalk 2
. Idk then. I love this rom tho. Just needs the settings fixed and Phone and its all good.
Aruz530
