[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
I noticed when when loading the quattrimus kernel, super user tends to not work... I think just leaving 17c alone is fine
Sent from my GT-P3113 using Xparent Cyan Tapatalk 2
Re: [ROM]COLD AS ICE-CM9 Sprint LS670 9/1 ZVD basesband Alpha17
1X Data isn't working. Says connected but no data. The signal bar remains grey and doesn't turn to blue to indicate a connection.
Known Problem?
Known Problem?
What build using.?
What build using.?
Alpha 17c latest.
Also, the phone keeps saying Android is upgrading and optimizing 1 application on reboot.
Got 17c to boot. Runs great! Thanks
17c working for me... Try flashing, it again
Has anyone managed to get the Visual Voicemail to work?
Still no 1xRTT data for some reason. Says Mobile Network State connected but the 1X bars on the top left hand corner are grey.
Any idea what is wrong? I've only been able to get 1X data to work on the stock rom.
My phone IS flashed to another provider.
Does this log down below help at all?
Code:
D/ConnectivityService(  575): ConnectivityChange for mobile: CONNECTED/CONNECTED
E/ConnectivityService(  575): no dns provided for mobile - using 8.8.8.8
E/ConnectivityService(  575): exception setting default dns interface: java.lang.IllegalStateException: Error communicating with native daemon to set dns for interface
D/NetworkPolicy(  575): applying policy NetworkPolicy[NetworkTemplate: matchRule=MOBILE_ALL, subscriberId=valid]: cycleDay=7, warningBytes=5242880, limitBytes=10485760, lastSnooze=-1 to ifaces [null]
D/ConnectivityService(  575): NetTransition Wakelock for WifiStateMachine released by timeout
D/Tethering(  575): MasterInitialState.processMessage what=3
D/PicasaSyncManager( 1659): active network: NetworkInfo: type: mobile[CDMA - 1xRTT], state: CONNECTED/CONNECTED, reason: dataEnabled, extra: , roaming: false, failover: true, isAvailable: true
D/PicasaSyncManager( 1659): background data: true
D/TelephonyProvider(  759): Preferred APN: -1
Also, is the installation of Mount2SD possible with the latest build? I haven't been able to make it work -newbie on this. My partitions are FAT32/ext4/swap.
Code:
You will need to set the apn manually for your network. This is pretty much setup for Sprint and virgin only. And adjust the build.prop to your network also.
Sry im a noob and im running Xionia Clockwork CWMA v1.2518.6
i wanna install this rom but step 3 confuse me because i dont see a option anywhere to wipe BOOT or SYSTEM
STEP 3
3.Now wipe Data, BOOT, SYSTEM, CACHE from recovery
These are the only wipe option i have
wipe data/factory reset
wipe cache partition
and under the ADVANCE menu
Wipe Dalvik Cache
Wipe Battery Stats
If i can still flash this rom can someone tell me what to wipe and in what order from the options i have mention above
r3dpuk3
