[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
thekraven
1,407
1,148
CM9 Alpha build for Sprint optimus S
"COLD AS ICE"
ZVD only, but ZVJ works with the conversion patches
These are public test builds, so expect bugs. Test away and report bugs and what works for you. ETA's does kill puppies. So don't.
What works so far in CAI
Calls, 3G, wifi, gps, sms , MMS, camera with preview, video camera limited capturing, native usb, adb ,.headphones no mic, Youtube HQ works, HTML vids working. CM9 themes. Gmail whitescreen fixed.
What works so far in Paranoid android Tablet CM9
Calls, 3G, wifi, gps, sms , MMS, camera with preview(alpha10), video camera with videocam illusion from the market, native usb, adb ,.headphones no mic, Youtube HQ works, HTML vids working. CM9 themes. Gmail whitescreen fixed in 11/30 build More info here paranoid android info
Features
  • USB fastcharging kernel
  • Centerclock
  • status bar tranparency
  • i/o scheduler settings
  • circle battery
  • apps to sd-ex
  • recent apps switcher
  • navigation button options
  • hardware keys action
  • partition info screen
  • EGL tweaks applied
  • Root Browser file manager
  • zip aligned
Not working
Video playback in gallery. Use quickpic or install mx video from the market. native tethering
BUILD CHANGELOGS
ALPHA 17 Panoramic camera fixed, not as fluid, but works, new test18 kernel with deep sleep fixes. Trying a few patches for clock sync issues. Gmail blank screen still has issues, but working on it. Center clock patch added. CPU rendering disabled thanks LeoLawliet. Transparency patch added. Custom key longpress functions added. ALpha 17F includes new usb fast charge kernel. See post 2 for more info. Slowly adding in blank gmail/fb fixes. Fixed Camera selection icon overlays. Reduced Font folder size. Alpha 17G , new audio routing...test for notifications playing in the headphones... Added home button answers call option. Fastcharge kernel and fastcharge toggleswitch options. You will need to flash the 17G fastcharge setting patch below. Comes with Test 19 kernel.
ALPHA 18 .
  • More gmail whitescreen fixes... aosp fixes getting patched.. maybe next release.
  • Added Fastcharge toggle to the notification drop down. .. Remember to turn it off/and replug the usb to use mass storage.
  • Sprint VVM 9016 fixes.,Nav bar buttons and option,Circle battery mod and Line battery
  • hq youtube fixed thanks to ganster and omxcodec.. fixed software decoding of Youtube HQ vids.
  • adding in gmail whitescreen fixes from oxygen... not finished.
  • test 23 kernel. Seems to suffer clock lag, flash test 21 kernel as a temp fix
ALPHA 19E
  • Gmail whitescreen fixed version1 thanks popdog123. Same fixes as in Oxygen rom. It might make some apps incompatible, so report if any.
  • Apps to ext and dalvik cache to ext option in performance settings thanks Nobodyatall. Choose a2sd for only apps moved to sd-ext. Reboot to take effect. Choose d2sd for dalvik + apps to sd-ext. Reboot to recovery and wipe dalvik. You may need to manually delete the data/dalvik cache folder. If you like the old way of automatic app to sdext, swap out the init.d folders from my old builds.
  • I/o Scheduler settings
  • recent apps switcher ported from AOKP
  • html vids in webpages should be working thanks ganster41
  • if you had youtube reboots, it's now fixed by hephappy
  • Still has test kernel 23, But try out any of the newer kernels to your liking. Test 21 still gave the best ontime clock
  • known bug when viewing html vids in the browser then switching to the Youtube app, the vids are choppy. Force close the browser and youtube app to fix. This is due to the codec not getting released between apps.
Bugs
DOWNLOADS AND GAPPS
No mirroring or repackaging. But patches are fine. Paranoid Android for thunderc build 1: For more info paranoid android info ALPHA 19E Goo.im Downloads - Downloading alpha19.testE.cm91-20121120-kraven-LS670.zip MIrror1 alpha19.testE.cm91-20121120-kraven-LS670.zip GAPPS
  • GAPPS TEST1. Less downloading needed, but remove what you don't want. Testing different install scripts. This one can be installed right after a rom flash. Then turn on a2sd or d2sd. Gapps with hacked market for dpi changes, includes gmail, google voice, youtube, titanium b/u free version, rootbrowser free, and amazon app store installed to data/app or sd-ext/app. Just delete what you don't want in the zip..data/app folder and flash. Goo.im Downloads - Downloading gapps-ics-20121207-3.zip ~42 MB
  • GAPPS TEST2. Same contents as above. Install goes like this. Install rom. Reboot to system. Turn on A2sD or D2sd if you have an sd-ext partition .Reboot to recovery and flash this Gapps This should install to sd-ext parttion.. Goo.im Downloads - Downloading gapps-ics-20121207-8.zip
Older Gapps with non working voice search, but includes news and weather widget. Just uninstall voice search via titanium backup and install in Google play. https://docs.google.com/uc?authuser=0&id=0B7tYmKVsZzWzbWtieUJ6REE1Wk0&export=download Or try out quattrimus builds by tdm for ls670 phones. It should be pretty close in builds except for kernel and recent apps. http://forums.androidcentral.com/op...acks/156426-rom-alpha-quattrimus-ics.html#anb Gapps changelogs Google
Install instructions
Install 1.Make sure you are on ZVD radio(sprint only), rooted, and custom recovery installed. Only Xionia and drew's Cannibal recoveries are tested. 2.Boot into recovery and nandroid your setup as this is alpha and may not be a daily driver for most. 3.Now wipe Data, BOOT, SYSTEM, CACHE from recovery. 4.Flash the rom zip, 5.Flash gapps for ICS, 6.then reboot. First boot will be long. 7. If wifi doesnt turn on, turn it on and reboot. Old bug, but should be fixed now 8.Post any bugs or fixes you find here.
Sources
My github https://github.com/thekraven
Kernels. Use built in kernels or check post 2 for updates.
Kernel sources
http://forums.androidcentral.com/lg...el-gb-ics-hydrokernel-v01pre3-oc-enabled.html
Gingerkernel ICS kernel zvj https://bitbucket.org/drewwalton19216801/iscream_thunderc-2.6.35-rebase/src
Gingerkernel ICS kernel testing https://bitbucket.org/thekraven/iscream_thunderc-2.6.35-rebase/src
Lupohirp P500 cm9 [UNOFFICIAL][DEV/GEEKS-ONLY] Cyanogenmod 9 (Android 4.0.3)[BETA3 WITH FULL HW/A] - xda-developers
tdm VM670 cm9 http://forums.androidcentral.com/op...acks/156426-rom-alpha-quattrimus-cm9-ics.html
Team Hydro zvh cm9 http://forums.androidcentral.com/lg...m-cyanogenmod-9-lg-optimus-s-yes-its-ics.html
Rootbrowser file browser https://forums.androidcentral.com/e...id=com.jrummy.root.browserfree&token=1P0IrIlu
Donations always accepted. Donut fund.
Big thanks to all the testers and donaters and devs for ICS: drew, Tdm, jerryscript, Bobzhome, blarf and iho crew, mrg666,lupohirp, androidmeda, adfad666, jasonevil, cyanogenMOd
  • audiofix4.fromA14.CAI.zip
thekraven
1,407
1,148
Re: [WIP][ROM]COLD AS ICE-CM9 for Sprint LS670 ZVD basesband on
HOT FIXES: If stuff don't copy correctly, ie wifi drivers, try mounting system in recovery, then flash. Always flash kernels last after patches or boot.img. Try turning on wifi, then reboot. Turn off haptic feedback on the keyboard to get rid of any typing lags.
Better battery life
I've been using CPU tuner and life has been pretty good as CM7 https://forums.androidcentral.com/e...5hLmFuZHJvaWQuY3B1dHVuZXIiXQ..&token=JeqgMvpH These are my settings that I use, you can adjust the pulse settings for mobile data and sync if you choose. Mine are set to check every 15 minutes and stay on for 5 minutes. Just unzip and copy the apple folder to your sdcard @ /sdcard/ch.amana.android.cputuner/configurations/ http://forums.androidcentral.com/attachment.php?attachmentid=36675&stc=1&d=1347053457
CAI ALPHA 19 patches
  • 12/2 Gallery video thumbnail fixes from hephappy and latest omx fixes from Ganster41, it should work for Alpha 19E and the Paranoid 1.6 builds. Flash in recovery View attachment 49210
  • 11/20 Virgin 19E patch.... View attachment 47710
ALPHA 18 fixes
11/11 Virgin fix2 for alpha 18 View attachment 45736 Build.prop fixes should help with market compatibilyt. 10/30 Alpha 18C, 3rd party wifi tether mix.. reverted something that could have broke it. View attachment wifi.3rd.partyfix.alpha18C.zip 10/29 Alpha 18C only Panoramic fix. View attachment Panoramic.fix.alpha18C.zip 10/13 Virgine fix for alpha 18 updated above 10/08 VVM visual voicemail fix for sprint 9016 text messages. For those that don't use google voice. You will still need to install the sprint vvm apk. http://forums.androidcentral.com/at...zvd-basesband-alpha17-vvmfix2.cm9alpha17g.zip
ALPHA 17 patches
10/10 VIrgin fix for alpha 10G try 3. View attachment Virgin.fix3.cm9alpha17G.zip 10/08 VVM visual voicemail fix for sprint 9016 text messages. For those that don't use google voice. You will still need to install the sprint vvm apk. http://forums.androidcentral.com/at...zvd-basesband-alpha17-vvmfix2.cm9alpha17g.zip 10/07 Virgin fix for alpha 17G only ... didn't work. Made the phone fc 10/06 Fastcharge switch for alpha 17G 9/20 Fastcharge toggle...turn on/off added to Settings/Device/Advanced for use with Alpha17F. Behavior: Checked means USB fastcharge activated and adb functions are off. Unchecked is normal usb slow charge and adb functions like normal. http://forums.androidcentral.com/attachment.php?attachmentid=38013&d=1348159323 9/30 Old fonts folder... should fix Japanese and Chinese characters. Wipe cache and flash the file.http://forums.androidcentral.com/at...d-basesband-alpha17-oldfonts.cm9alpha17f-.zip Test19 Kernel with Fastcharge via USB patch http://forums.androidcentral.com/attachment.php?attachmentid=37535&d=1347691495 See this post for more info http://forums.androidcentral.com/lg...-1-zvd-basesband-alpha17-147.html#post2155852 Virgin fix for alpha17a-17f only builds http://forums.androidcentral.com/attachment.php?attachmentid=36599&stc=1&d=1346971919
kernels
Test 21 kept battery stats and no clocklag.
Template.zip for manual flashing. I recommend using 7zip to open the zip files, and notepad++ to edit files. How to flash zip your own files. I push my files via adb commands, but this should help those that can't do it. Open the template zip. And drop whatever files you want to flash. For example, say a MMS.apk goes in /system/apps, a bootanimation.zip goes in /system/media , gps.conf goes in /system/etc. SystemUI.apk goes in /system/apps, frameworks-res.apk goes into /system/frameworks . Place whatever file you want to flash in the correct directory in the zip. Like for the build.prop, edit how you want it, then place in the /system/ folder. For apps, /system/app/ Now copy to your sdcard and flash in recovery with signature off. 1.Notepad++ http://download.tuxfamily.org/notepadplus/6.1/npp.6.1.Installer.exe 2.7zip Download 3.template.zip OLD STUFF: OLD kernel links Old ICS kernel.. hydrokernel by ddrewwalton192168 http://forums.androidcentral.com/lg...el-gb-ics-hydrokernel-v01pre2-oc-enabled.html Old ICS CM9 kernel by drewwalton192168 http://forums.androidcentral.com/lg...ernel-gb-cm9-iscream-kernel-v01-ics-baby.html Old GingerKernel 8.1, thanks to drew for allowing use. http://forums.androidcentral.com/lg...kernel-v08-1-oc-double-tapping-bug-fixed.html Gingerkernel repo https://bitbucket.org/drewwalton19216801/gingerkernel-2.6.35
  • Fastcharge.cm9alpha17F-signed.zip
  • Virgin.fix2.cm9alpha17G.zip
  • Virgin.fix.cm9alpha18.zip
  • hk-ICS-CAI-test17++kernel-signed.zip
  • hk-ICS-CAI-test19-fastcharge++kernel.zip
  • audiofix3.fromA16.CAI.zip
me2151
272
123
Yay i got credit for something :D
i may go back to zvd just because there is no improvement for zvh(cough i think drew gave up on us cough) :/
drewwalton19216801
2,476
2,803
Yeah boi! Git er done! Heh heh get it? Git? :p
Btw lupohirp re-uploaded his source including his kernel. Full hw acceleration is near I think.
Reactions: darktoy
ab304945
1,593
54
nice!!
I might revert back to VD to try it out, but that seems like a lot of work. lol
ab304945
1,593
54
Installing it now.
Was a pain in the butt it revert back to VD, but i did it.
rukin5197
1,105
628
Can anybody report to me whether or not mic works with my gapps? I deleted some files that might be needed for that..
Just need to know whether or not I need to add it back in :)
noonebutkev
76
4
it works fine :)
the first time i tried it force closed the market instantly
Reactions: thenameisnigel
sdaservices2000
