[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 4/5 ZVD basesband Alph
I'd like to test as well if thats ok with you!!!! :D
I would love to try a10 because I just cant wait no longer for it
WIFI is a lil buggy on A10b for me, running test 5 or 6 kernel. will flash A10 later and install kernels, see where it goes from there....3g is stable, however, seems to connect fast and stay that way. The sense app killer is SICK. really nice addition.
It seems like everyone is a tester now
There's a few new wifi settings in the test 2 ramdisk. I'll probably go back to the previous setup. Thanks.
Cool cause I already miss the test 6 kernel. Its really responsive. Probably flash it on A10. Thanks again!
Sent from my LS670 using Tapatalk 2
Lots of issues.
Wifi as mentioned. Weak, issues with Google sync connection.
3G flaky connection, in previous known good places. Google sync issue as well.
Major time sync problem, with the screen clock vs notification bar being 45 minutes to over and hour off. Caused calendar alarms to fire way way late as well. Missed a couple phone appointment calls.
Calendar and Gmail sync are problems. I had to go into Settings, Accounts and Sync, then uncheck and recheck them to update. Adding calendar events or sending emails does not update on Google server end. Deleting or archiving emails from the phone, same issue. Tried both 4/29 then 4/22 gapps.
None of my syncs work, no notifications - Craigslist, Tapatalk, Twitter, Facebook, ESPN Sportscenter, Had to manually open each for updates.
A10b with Gapps as above, your kernel in ROM, no additional items flashed.
Lots of errors in logcat (attached)
Reactions: Thraeryn
thekraven;
PMed you a couple of days ago, just wanted to let you know that I am always down to test the latest and greatest! I've got a NAND of CM7.2 on backup, so I'm ready for whatever comes my way :P
wifi wasn't just an issue at work, home is very slow as well even after multiple reboots. however speedtest.net shows similar results to prior alphas of 7000kbps even though pages are seeming to load slower. 3g is slower in a10 test 2 speedtest.net is between 175kbps - 325kbps a8 and a9 were around 400kbps to 550kbps.
I'm not having the app sync issues. after more time passed I did notice that the clocks do in fact lag but correct faster.
battery seems to go a little quicker than a9 with hk Oc at 768. currently have set to default CPU settings.
app switcher is an awesome touch. just noticed that downloading files seems very quick
Wth? Why isn't the thing keeping time? It was fine for a couple of days then it started this. Is there a fix?
sent from my ice ice baby too cold
I'd love to test your a10 on my OV. I want to try to get a button fix for the rest of the OV community when it's released, so there's no waiting or clutter posts about it. PM me if you can. Thanks.
Time has been off in the last few releases, the reason? This is an alpha build, everything is work in progress, everything breaks, everything needs a fix, fix one thing, break three or five or ten; standard for an alpha. As this progresses, more things will break most likely. Each one does not necessarily get better, sometimes they are worse, like this release. Name of the ALPHA test game. You want a total fix? Hang around for a few months, my guess is at least six months, probably more.
Flashed Drew's refresh of HK 01pre4. My wifi icon went blue for the first time, and I successfully sent an email, deleted an email, and archived one. Also added a calendar event and it shows on the web via desktop browser.
Does flashing the kernel change the ramdisk in this case?
No, it could be the wifi drivers. When they are built with the rom, they get shrunk by a good margin. My wifi stays blue. I'll make a few boot.img available along with the alpha 10a boot.img/ramdisk available to test too.
I went and did a complete manual wipe before installing a10b. I'm not getting time/ clock lag or sync or wifi issues. I'll report more when I get off from work tonight.
Reactions: Pkt_Lnt
I know what an alpha build is, I've just never encountered this problem with time before
r3dpuk3
