[ROM][CyanogenMod9/AOKP][WIP][THEMED]VanillaBean
Status
Not open for further replies.
Go to mounts and storage in recovery and mount system, then go to flash zip from sdcard and flash it.
Are the animations working?
Yeah, but they don't seem exactly like JB. Apps open in a smooth transition, but they don't open from the apps location...if you know what I mean :p
In the thread they said they were ripped from jelly bean but idk.
I don't think so, its really close, but not exact. Better animations than ICS though :)
Reactions: Zakman
I've actually seen that file and it's among my VanillaBean builds\JB files\Apps\ICS\APKTool\Random other JB stuff to port over on my Flash Drive. If i can successfully decompile Framework-res ill put them in :P
Reactions: JadenBrown30
Try decompiling the originial framewrork-res then do what you need to do then recompile it. Then use 7zip to edit the png's.
Sent from my shole using Tapatalk 2
When I decompile it/recompile it via APKTool I get issues in both things. False files, exceptions, and the like.
As for editing images- isn't it more complicated then just replacing the images in 7z?
I installed this rom, everything is going good so far except for the google now. It keeps throwing the google search has stopped working error when it tries to run. Also I don't know what it is but the standard email client won't connect either. It gets stuck on checking incoming server settings, then just closes. I know the information is correct.
What I would do is flash ur current rom then flash my zip the from root explorer copy the framework-res file to the sdcard and use that.
And you can find a jellybean theme from the play store :)
Could I suggest using a sprint prl maybe inverted mms other then that works great
Sent from my LG-VM670 using Xparent ICS Blue Tapatalk 2
About to flash this in a while, I wonder how Jellybean development is going for our device?
Sent from my LG-E739 using Tapatalk 2
Status
john_russell
