[ROM][CyanogenMod9][Themed][Updated] VanillaBean:V2
Damn it. Seems the mod only works on HDPI. If I can get it to work on the Opt V, you guys will know. But for now flash yesterdays and report bugs etc.
Downloading this now. If its more stable than aokp beta2 I'll be making the switch :)
I think stability should be the same, they're both based of Quattrimus Beta 2.
The one from yesterday is the one already posted..
thats what i was noticing. good looking rom, any way we can get blacked out google apps for it?
This is awesome. Small bug I found - when you pull down the notification bar, the very bottom (around the blue horizontal bar) is completely transparent. I think this is supposed to be dark like the rest of the notification screen.
Yeah, that's a problem with the theme I originally used by Android Customize. I'll see what I can do to fix that up all nicely. If I come across a way to get voice working, which I doubt since Quattrimus' standard voice never worked, I'll put it in:P
To get it to work do thus
Remove voicesearch.apk from rom and have users install by themselves it should work
Sent from my LG-LS670 using Tapatalk 2
This Rom is good better than the first one. Just a question but is the notification drawer going to be jelly bean style with expandable notifications that's one thing I really like about jb.
Don't think the expandable notifications are doable but the t heme with all the colors and all should be doable.
Also, Jonny, GNow has a different VoiceSearch apk with different innards so Idk if it'll work
Nice job on v2!!" I also have a bug report, when on the lock screen I can't reboot the phone!! I have to first unlock the phone then reboot :D!
Hmm, probably a Holo Locker issue, check your Holo Locker settings? Maybe there's something in there you can change :P
Go to Menu-> Select Settings-> Go to Applications
Click on Manage Applications and now select “All” tab
Select Google Play Store App
In the next step, you need to Clear Data and also the cache.
Next time you start Google Play, you will be asked to login again and the error might be fixed.
Sorry if I come off as ignorant, but I'm really excited for this ROM, and also a bit confused.
What is the status of Google Now in this ROM?
liquidsnake757
