[ROM][CyanogenMod9][Themed][Updated] VanillaBean:V2
So I flashed your ROM. I really have to say I'm impressed! This is your first time? You've done well. I logged in last night looking for something to replace IHO BACKside CM7, and the very first thread I saw (yours) was an immediate win.
I'll point out a few things that are not working right, so that in your next update you'll know what to check out:
+The very bottom of the notifications dropdown is entirely transparent.
+When I exit Google Play and come back, the app shows up at the main screen, rather than what I was on before I hit the home button.
+The stock locker and Holo Locker both appear when the screen is unlocked.
+The circle-figure for the stock locker is positioned as if it were dragged downward until only half of it is showing, in both the lock-screen and the lock customization screen.
+I don't know if this is in relation to the ROM itself, but batch restore operations in Titanium Backup freeze after the first app is restored. (it won't move on to the next app and I have to force close TiBackup to close the operation)
If I come across more bugs, I'll let you know! Other than that, thanks for the ROM!
+Any time I go to to input a URL in the stock browser, it closes saying that Google search has stopped.
+GPS fuelled apps don't work. (E.g. CardioTrainer, etc.)
Loving this ROM so far. I am new to this, having been rooted only a week now.
I am having a problem when getting apps from Play Store though. I get insufficient space errors even though I have plenty both internal and external space. If I reboot, I am able to install one app at a time.
Also I get Google Search FC popups often.
when I try to reboot in recovery it just reboots my phone so I have to reboot manually
Device is seen on Bluetooth but drivers can't be found for the device. I restored to a CM7 GB mod and Bluetooth works fine.
Also, what SD card partitioning do you recommend for this mod on a class 6 32gb card?
1-2gig partition on a ext3 or 4 I use 3
Sent From An Optimus s
No, I just felt like posting it in the Optimus V forums!!!
With the release of 4.2 I'll try to get 4.2 things like updated Google Now and gesture typing (Photosphere even) for future releases as they become available!
So you just posted it in the ov forums yet made it confuse people lol?
If I make a 4.2 version I might have to ask BobZ to use his CM10 rom since most things won't work on ICS..
Guava121
