Looking for clockworkmod, now that I am on this ROM. The above link is 45 pages![]()
Can I just install clockworkmod from the market?
It seems about the same speedwise and battery life, but his rom has a more unified theme to it ,and cleaner look than mine. And im sure he is going to come out with some great updates as he is alot more experienced than i am![]()
DroidXcon - Don't go selling yourself shortyour ROM is coming a long nicely. I like it a lot! Where did you find the wallpaper so I hope you are going to continue to develop yours.
I would like to see a battery icon like yours get incorporated into GummyCHARGED, I like have the battery meter at a glance.
Keep up the good work.
no way!! if you are on my rom go to the app drawer, open quickboot and hit recovery
So, I want to try this ROM out......
Currently running DroidX's AB 4.1. All I do is disable lagfix & then flash this with CWM........correct????
If I want to go back to AB, I just flash with Odin right??
You need to install CWR, I don't believe the one from Rom manager is working.. And in order to get it working you may need to romove the lagfix... But my ROM will work with or without the lagfix
kejar, just to make sure
CWM & CWR is the same thing??
I thing that I meant CWR in my earlier post. I boot into recovery & see red letters right?
