ARCHIVED: [ROM] - gROM 2.2 - 10/16 - GB - With Flash - Yes, FLASH!
Status
Not open for further replies.
Re: [ROM] - gROM 2.1 - 10/8 - GB - OC'ed - Infinite Possibilities
Thank just wanted to know your thought on that but I kind of like the theme chooser you know how it does theme the whole ui
Yeah, but ROM has a themer too ;)
Scrosler just want to say thanks for your hard work sometimes its better to have a simple rom
Your welcome!
Quick question how do.i enable data2ext on terminal
You cant. I did not add the scripts for it yet. I will next version. Did not have to play with it so I figured I better hold off for now.
can i use titanium backup to restore my apps :-$ im on reborn
Whenever I try to download it downloads a 100mb file ...downloads.php...what's going on?
You can but I recomend starting fresh. This is a whole new OS version!
What browser are you using? I did it in Chrome and IE9 and has no issues.
im having an issue when installing the rom. it says signature verification failed. what does that mean. i followed the rooting process before trying this.
Really? The ROM is signed. So you should not be seeing that... Let me download and try. Maybe something got corrupt on the server.
Well, I just downloaded it and it passed Signature Verification for me. So that means one of two things. The file got corrupted when downloading or the file got corrupted when transferring it to your SD card. You can tell if the download is bad by using your favorite MD5 hash check. It should be: 5B67CACC06FCE243CE72987714A85A07
LMK!
ok, i checked the file and everything is fine. how can i tell if i have a custom recovery installed? i think i missed a step somewhere lol.
When you boot into recovery does it look something like this?
attachment.php
my recovery dont look like that. i believe i found the step i missed.
well i got your rom installed finally. apparently i missed a couple steps lol. everythings looks 10 times better now. thanks alot for this. one question though about the no-frills cpu control program. its showing max 748mhz/245min for the default cpu clocks. so i just check the apply at startup box and im good to go? i also noticed in the governor tab, theres a few settings. default was ondemand. im assuming that is a power saving feature. i noticed there was a performance selection in there as well. im assuming if i select that, i will be at max clocks all the tome?
sorry for all the questions. just want to make sure im understanding all this correctly.
The different gornors manage your cpu levels to help conserve battery or maximize performance. Most people seem alot more concerned about battery life, but want a governor that will kick up the cpu as needed. Ondemand, Interactivex, SmartassV2 are really good at power management AND performance. Try them out and see which is the best fit for you.
Wow, this rom is really slick. I am glad I took the time this morning to update to zvh, and it boots super quick. ROMupdater is great.
Waiting for the data2ext on the next version, I like to have all kinds of stuff installed. hehehe
Status
yumikogre9
