[ROM] ICS SDK Port [WIP]
Status
Not open for further replies.
So here are some bugs I have noticed so far:
1) Icon Folder names do not stick after reboot..
2) Re-arranging icons/widgets for too long (especially icon folders) will cause a system reboot..
Here is a zip with fonts. It is not flashable, just unzip and copy these to your /system/fonts directory.
If you haven't done this before...
Flash superuser
Download ES File Explorer or Root Explorer from the market
In settings of ES File Explorer, grant root and make system writable
Unzip fonts.zip to sdcard
Copy fonts to /system/fonts/ and overwrite everything
Reboot
Thanks! Can you link me to superuser?
superuser is in the market!
I have found only FC I get are with Google Voice.
Wifi Works fine
Didn't test BT
but overall this is a great rom!
Thanks to all involved
Big thanks to warttack he is the man!
I made an account just for this, thank you so much Beezy and the rest of the gang involved in the SDK port. Sure it won't be perfect, but your effort goes a long way for us curious types.
Thanks again, you guys are spectacular.
Thanks for the account at Android Central... Look around you will find much more here at AC than this awesome ICS ROM.
I remember earlier that someone said the folder was getting renamed on reboot. I haven't had that issue but try make the same folder delete the old and reboot.
Status
The Burg0964
