[ROM] ICS SDK Port [WIP]
Status
Not open for further replies.
I use the larger font. It looks better in my opinion and fills the display better.
Same issue here, it makes the screen look smaller than it is lol.
I'll post some screen shots, but nothing special really, using the same stuff I was with gingerbread.
Sent from my Nexus S 4G with Ice Cream Sandwich
The whole scroll bar misalignment issue probably has something to do with the multiple resolutions and screen sizes that ICS handles. Something probably isn't just tweaked correctly at this early stage. After looking at the framework-res and most apps associated with ICS so far they have almost a dozen "png or image" folders now each dedicated to fit a certain format/device depending on if its tablet or phone that its running on. Normally you had ....
drawable (this was xml codes)
drawable-hdpi (most commonly used images/pngs)
drawable-land-hdpi (extra pngs specially thrown in for landscape mode)
Now there is half a dozen or better drawable-xxxxx folders since ICS combines both tablet and phone under one OS.
Basically, it may have to wait until official release or source is dropped before this is ironed out on some of the exact alignment issues.
Whatever you do, make a version with the search bar, in case I like your theme. :P
Actually after looking into the code a bit... If you don't use the included stock launcher then the search bar doesn't appear at the top of the home screen.
I installed ADW EX Launcher and search bar at the top was gone.
The code for the search bar is in two parts.... Part of it to "activate it" is in the Launcher2.apk and the rest of the code is in the framework-res.apk.
So if you don't want that search bar at the moment just flash a 3rd party launcher. Otherwise I will try and post a modded Launcher to flash a little later this evening. Shouldn't be a problem to remove.
Reactions: intheb0x
Yeah, I was just saying that if you make a themed version, make a version that includes the Google search bar at the top, because I like it and I'll want it if I like your modded launcher. :p
Hey guys I manage to change my Android version from IceCreamSandwich to 4.0. Also my build number just says IceCreamSandwich IRK40C. LOL
I don't know if this is only my phone but the wallpaper crop seems to be off for all the wallpapers that i download from something like zedge, and even the stock gingerbread wallpapers too. Is there a way to fix this or some place i can get wallpapers that actually FIT. Thanks.
What do I change in build.prop?
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=IRK40C
ro.build.display.id=sojus-userdebug IceCreamSandwich IRK40C 162682 test-keys
ro.build.version.incremental=162682
ro.build.version.sdk=13
ro.build.version.codename=IceCreamSandwich
ro.build.version.release=IceCreamSandwich
ro.build.date=Tue Aug 9 16:52:52 PDT 2011
ro.build.date.utc=1312933972
ro.build.type=userdebug
ro.build.user=android-build
ro.build.host=android-test-34.mtv.corp.google.com
ro.build.tags=test-keys
ro.product.model=Nexus S 4G
ro.product.brand=google
ro.product.name=sojus
ro.product.device=crespo4g
ro.product.board=herring
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=samsung
ro.product.locale.language=en
ro.product.locale.region=US
ro.wifi.channels=
ro.board.platform=s5pc110
# ro.build.product is obsolete; use ro.product.device
ro.build.product=crespo4g
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=sojus-userdebug IceCreamSandwich IRK40C 162682 test-keys
ro.build.fingerprint=google/sojus/crespo4g:IceCreamSandwich/IRK40C/162682:userdebug/test-keys
ro.build.characteristics=nosdcard
# end build properties
# system.prop for smdkc110
rild.libpath=/vendor/lib/libsec-ril.so
rild.libargs=-d /dev/ttyS0
ro.sf.lcd_density=240
ril.ecclist=911,#911,*911
# ADDITIONAL_BUILD_PROPERTIES
ro.cdma.home.operator.numeric=310120
ro.cdma.home.operator.alpha=Sprint
ro.telephony.default_network=4
ro.wimax.interface=uwbr0
ro.opengles.version=131072
wifi.interface=wlan0
wifi.supplicant_scan_interval=15
dalvik.vm.heapstartsize=5m
dalvik.vm.heapgrowthlimit=48m
dalvik.vm.heapsize=128m
ro.config.ringtone=Sceptrum.ogg
ro.config.notification_sound=Castor.ogg
ro.com.android.dateformat=MM-dd-yyyy
ro.com.android.dataroaming=false
ro.url.legal=http://www.google.com/intl/%s/mobile/android/basic/phone-legal.html
ro.url.legal.android_privacy=http://www.google.com/intl/%s/mobile/android/basic/privacy.html
ro.com.google.clientidbase=android-google
ro.config.alarm_alert=Alarm_Classic.ogg
ro.com.android.wifi-watchlist=GoogleGuest
ro.error.receiver.system.apps=com.google.android.feedback
ro.setupwizard.enterprise_mode=1
keyguard.no_require_sim=true
drm.service.enabled=true
dalvik.vm.lockprof.threshold=500
dalvik.vm.dexopt-flags=m=y
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
Ok, thanks, and what are you guys using to view/edit xml's?
You have to use APK TOOL or APK Manager to decompile the apks and then Notepad ++ to view the XMLs...
At this point I really wouldn't recommend messing with it as I'm having enough of a hurdle doing these little things because without official source being dropped the tools required to de compile (baksmali and APK TOOL) are not yet updated to support ICS and de compiling has been a real touch and go situation....
On another subject about modding in the build.prop, you can change those lines in the About Phone to say whatever you like... They can say Batting1000's ROM if you like... That is why in the early stages months ago when the first leaked pics of ICS came out people said it was themes and then people just modified the build.prop to say ICS 4.0 or whatever they like... Oldest trick in the book...
Reactions: vhgomez36
Its fairly easy though and I know I'm going to wipe it once the update comes up.
ro.build.id=IRK40C
ro.build.display.id=sojus-userdebug IceCreamSandwich IRK40C 162682 test-keys (this will change the BUILD NUMBER)
(I forget which one of these two but one will change the ANDROID VERSION)
ro.wifi.channels=
ro.error.receiver.system.apps=com.google.android.f eedback
net.bt.name=Android
The rest all have a purpose and I wouldn't change them because they will affect things in the ROM. The only other things to really toy with is in the last paragraph I highlighted 3 lines that controls the stock setting for the notifications, ringer and alarm sounds...
Reactions: mcollini
ro.build.id=IRK40C
ro.wifi.channels=
net.bt.name=Android
Awesome. Thank you.
Sent from my Nexus S 4G using Tapatalk
Status
CasperTGhst
