[ROM][ICS] the GODZILLA ROM 10-20-12
Re: [ROM][ICS] THE GODZILLA ROM tweaked and themed cm9!!!!!!!
What happened to my news and weather app it disapeared after in installed 3.5 how can I get it back where to download from?
Sent from my LG-VM670 using Xparent Pink Tapatalk 2
just open the previous builds zip, connect phone via usb storage, drag/drop or copy/paste the app you want from previous build to sdcard... unmount usb storage, use a root capable file manager to move it from sdcard to system/app, reboot...
That's what I was gonna do but u saved me time
Looking for good cm9 or cm7 themes??? visit this site for good themes. http://forum.digitalhouseoftreats.com/
Hmmmmmm weird I can pull apk 's for you tommorow
Didn't disappear for me
But tommorow at the crack of dawn I will pull an apk file and upload cuz its 11 almost where I'm at
CRAZY I looked in system apps it was there news so I tried to reinstall it said it didn't but it was so its all good now
You're 13???? Nice I know how to port anything based on CM7, but ICS??? That's hard. Oh and I'm down to test, I do wish there was an option so the status bar wasn't transparent.
A fix is applying a new theme it will remove the translucency I believe sorry if it annoys enough people I will remove it
Btw being 13 gives me all summer to work on it
I have a question. Why are you taking over something for a phone you dont have. Especially with it being the first thing you've ever done.
EDIT: don't take this the wrong way. Just curious
Thats so cool, your only 13!. your doing a great job
Is anyone else having problems downloading the Build, after 47.4 mbs?. "Download interrupted"
Guys, this is nothing new. Thread is being spammed by comments that can be solved from 1 apk install. e.e
@Johnny, if people are having sound problems, I suggest dis-including the beats. That's why some people make flashable zips :P
I looked into it the guy was talking about joyfully optimus OOPS
You know what cuz I can jkjkjk:p
I thought it might be fun and if it boots on my phone then I can sorta test it
Reactions: sellers86
Okay tested and the app is there, also everything work, except for the Bluetooth off, it reboots your phone but that a known cm9 bug, really looking for your release! :D
Good will be working on miui gb and thatguylurkin I belive is working on miui v4
This is really nice.. Been running all day and love it. Like everything about it so far... Thank you..
Sent from my VM670 using Tapatalk ? to here.
Reactions: Badboytoast
Johnny since the bass beats I think it lowered sound on plugged in speakers headset cause I can't make it louder with custom dsp settings:(
Gremlin69
