[ROM] JB 4.1.2 SlimRom for LS670 3.1 Build3
Hey was in school today and my phone vibrated like crazy for 1-2 minutes with no notification. Bug maybe?
Sent from my LG-LS670 using Tapatalk 2
Anybody else having data issues? I'm still trying to determine exactly what causes it to drop out, but when it does, I have to reboot?it won't come back by toggling. Also, turning on the speakerphone mutes the mic.
Yeah, I'm with you there. I assumed it was the same issue Bobz JB ROM was having, where it cuts out during deep sleep and won't come back without a reboot. But I can't say for certain what's causing it, I just know it's happening.
I can confirm this as well, I've tried going into airplane mode and back, but it seems to only way is to reboot the phone. Also as a side note, the mobile data toggle on the notification drawer power widget doesn't appear to do anything.
Hmm I'm not on this rom now but I didn't have data problems when I was.. Jonny you on zvd or j?
Tapatalk'n it from my VM670 running OM-Mandylion IHO on LS670ZVJ firmware
Not Jonny???
You said you weren't having data problems either so I just wanted to know what baseband you are on. Could be there's something in the zvj libs fixing the data problems if your on zvj also.....
Exactly, strange how I have 51 apps on cai and no memory issues there but when I flashed this rom, by the time I had the 19th app it said low memory :confused:
Sent from my LG-LS670 using Xparent Purple Tapatalk 2
I'm having a2sd I issues as well. I think mine have to do with my partition. Either the phone doesn't like my sd card, or the ROM doesn't like my partition (or both). I'm about to run a nand and repartition.
Don't forget to backup your sdcard a nand won't get that just ext
Zvd kind sir
Kraven u should change ur title to say build 4
Also quick question.... is it aosp source based?
So much for that theory. :)
This is just an observation, with no real testing behind it, but it seems like I can keep the data connection up as long as I keep wifi off. After wifi has been on for a few, if it's then turned off, I have to restart to reestablish the data connection.
Welladjusted
