[ROM] JB 4.1.2 SlimRom for LS670 3.1 Build3
Thanks for the ROM, seems to be working great. I was wondering if there was anyway to disable the Seeder script you added to version 4. There seems to be some controversy at XDA regarding its effect on battery life.
Revol APN's
<apn name="CDMA" numeric="310000" mcc="310" mnc="000" apn="0" user="" server="" password="" proxy="" port="" mmsproxy="" mmsport="" mmsprotocol="null" mmsc="" type="*" />
<apn name="Production" numeric="310000" mcc="310" mnc="000" apn="1" user="" server="" password="" proxy="" port="" mmsproxy="" mmsport="" mmsprotocol="null" mmsc="http://mms.revol.us/revol/mms.php" type="mms" />
<apn name="Android" numeric="310000" mcc="310" mnc="000" apn="internet" user="*" server="*" password="*" proxy="" port="" mmsproxy="" mmsport="" mmsprotocol="null" mmsc="null" type="null" />
<apn name="CDMA" numeric="31000" mcc="310" mnc="00" apn="1" user="4199601864@myrevol.com" server="null" password="revol" proxy="null" port="" mmsproxy="" mmsport="" mmsprotocol="2.0" mmsc="http://mms.revol.us/revol/mms.php" type="mms" />
Just delete the 11Speedy script in the system/etc/ini.d/ folder and reboot.
It's more likely to simulate the performance governor. So keep an eye on sleep and time @ frequencies.
Camera causes gallery to FC. On build 4. Worked fine on build 3
Sent from my LG-LS670 using Android Central Forums
Added a temp fix for the camera in the OP. It was the libcamera.so. The next build will have more fixes.
Loving this ROM! Great work as always. I seem to be having the radio issues from sleep like in Bobz ROM. If the phone goes into deep sleep, I have to restart to get mobile data back. No big deal really, but I didn't see any mention of it in the OP, or in any subsequent posts. I'm running build 3.
don't know if this has been brought up.. but I don't think the start up tweaks are functioning yet right? it sets but when you reboot, it reverts back
Tried this rom on Tuesday morning, couldn't get the gapps to flash though. I'll try it again sometime today. By the way, I have cai. Love that rom as well but wanted to do the slimrom :)
Sent from my LG-LS670 using Xparent Purple Tapatalk 2
Re: [ROM] JB 4.1.2 SlimRom for LS670 3.1
HI! I have flashed SlimRom Build 4, then flashed temp fix for camera build 4 Camerafix.build4.slimrom.zip, but there there's no camera's icon!?!
I have installed the ROM, did factory reset, wiped data and installed Camerafix.zip, but still there?s no camera?s icon. Maybe I did something wrong!?!
periyasamy
