[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
Re: [ROM][PORT][JB][07/30/12]CyanogenMod 10 [Alpha 6.1]
edit from before the com. android phone thing seems to be on start up only can anyone confirm? I restarted my phone and immediately went into app settings and it did that after settings fc'd
Good news though seems to be no more wakelock issues can someone confirm this as well?
Data seems to be broken , sounds work though but ... ( unfortunately the process com.android.phone has stopped) appeared once while trying to select a ringtone. (Unfortunately, Themes Provider has stopped) while trying to download youtube. youtube works flawlessly.
Google Now works flawlessly now with voice output! Fix 3G and I think we can move it to beta stage!
GPS Finally works for me!
Dont worry about the android.phone I think that may have been a one time fluke, I cant get it to reproduce.
Recap: YOUTUBE GPS SOUNDS GOOGLE NOW ALL GOOD
NOT WORKING 3G
Same here, no data, and mobile settings fc's.
okay, after looking some more, I noticed the more option under wireless and network settings is broken also, and when I try to call, instead of saying no service, it says to exit airplane mode
random wakelock fix not confirmed, just experienced it
dam.... confirmed as well.
mobile network not available when you go to make a call.
Flashing a new modem via ODIN doesn't help, actually makes it worse. Now, I get com.android.phone FC like every fews seconds.
you get my cat DK? any of that help? I also posted it to your non cluttered site.
slider shortcuts within lockscreen settings causes fc
Has anyone tested 4G in 6.1 or does the mobile settings FC stop this from being tested?
Also, I haven't noticed (or I missed it) bluetooth being mentioned in the testing. Has this been tested?
Awesome work so far DK2
no cell service in 6.1
should have known it wasnt 5:17 lol.
I would like to know if it works.
4g is broken, tried through the 4g widget
Status
ellahayes
