[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
Re: [ROM][PORT][JB][07/30/12]CyanogenMod 10 [Alpha 6.1]
I just realized I can't record video in alpha 4 anybody else?
... and due to a bunch of VM ..apparently a lot if calls are not coming through. Every once in awhile the phone hangs while making a call and I have to reboot...
confirmed on recording issue. I see the first half second, then black, but audio remains
Ok so that is really good. I will combine the Alpha 4 and the code adjustments from 6.1 to make Beta 1. Can you get me a logcat of the current sleep wake issue plz
This is great think you Dark Knight! Beta 1 in the works. Can't wait to get off work lol
Sent from my SPH-D710 using Tapatalk 2
Any updates on the never ending voicemail notification issue?
no issues with recording, however when playing back a recorded video the screen goes dark, but keeps playing(you can hear the sound) and yeah dk ill get you a logcat quick
Reactions: Dark_Knight2
DK I cannot get you a logcat computer is not recognizing phone atm. Can anyone confirm?
nevermind a quick reset fixed that, doing logcat now... but the wakelock issue does not occur when plugged into usb DK.
Basically after the first reboot I have a vm notification that never goes away. Says I have 5 voicemails.
I remember the same thing happened in ICS it was dubbed as "phantom voice mail" and it happened to about 40% of people that installed it
go through them and it should shut off, occured 1st alpha for me but i called my vm and listened to them and it was solved.
I'll get back to you on my findings once I reflash with the beta and get a GPS lock in gb I plan on staying on beta till things get sorted.
Well I did there's nothing in my inbox and I still got the message. Even with g voice enabled. I'll test more when I get on beta. I'm on my daily aokp ics for now. I'll let ya know
Does anyone know how to turn the log cat into a .txt file? I'm new to this adb and logcat stuff. Here to try and help DK.
Thanks in andvance
Status
Lilrose
