[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
Ah just put my baby daughter to sleep and came back to find a kang build :) dloading lol
Thanks dark
Sent from my SPH-D710 using Tapatalk 2
Re: [ROM][PORT][JB][07/30/12]CyanogenMod 10 [BETA 1]
Thanks dark
not for the faint of heart read thread updates before flashing
sorry for a noob question but what compiled mean ? is it different from the beta 1?
In a nutshell, Beta 1 is a "port" of CM10. It's built from a ROM that's already been compiled from a source code. The compiled version is one that was built from the actual source code.
Reactions: gotojanoo
it boots... cyanogenmod 9 bootscreen. not sure if i have a bootloop going on or not atm
I believe it is stuck in an infinite boot loop but you cant tell when it starts the loop over. just a pic of the cyangenmod android moving at the speed of light with a glowing white circle on his chest
edit: trying a restart will post back with findings.
edit2: after 5 mins or so it just stopped. Frozen I believe. Soft Keys light up when pressed though.
was able to get back into recovery though... flashed beta 1 again.
Thanks Jay .Appreciate. Am learning !!!!!!!!!!!!!! .I was wondering if i wanna go back to custom GB rom can i flash directly from CWM 6 ?
wife needed something, im back installing now
Hey DK wants me to use el26 kernel... I thought that was the one from the OP am I wrong?
If so please link or tell me where to find the one I need so I can continue testing this Kang.
currently it says 3.036-cmg60517f2-dirtysbrissen@sbrissen))#1SMP PREEMPT sun jul 29 15:39:59 EDT 2012 under kernel version
i downloaded the file via wifi direct to my phone then moved from my downloads to folder on my sd card flashed it and it stayed stuck on updating for like 10 min then turned off and just the blue light .......and fyi i can read thank you and tried to follow the instructions but it was my error so whatever now i have no phone..........risk you take right :'(
Can't u ODEN it back to health? Look up QBking77's videos on Youtube
Here is the EL26 kernel+CWM5: StockCWM-EL26.tar.md5
No he's superbricked unfortunately. Blue light = EMMC brick.
i got a error/status 7 installation aborted when flashing
Status
mohitsl
