[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
Re: [ROM][PORT][JB][07/30/12]CyanogenMod 10 [BETA 1]
i downloaded the file via wifi direct to my phone then moved from my downloads to folder on my sd card flashed it and it stayed stuck on updating for like 10 min then turned off and just the blue light .......and fyi i can read thank you and tried to follow the instructions but it was my error so whatever now i have no phone..........risk you take right :'(
What kernel/recovery did you use to flash the ROM? Be specific please. A link would be helpful.
oh ok i thought it was build specific - lol
ill try DK if its not too late
May answer other user's questions as well, did you place in the external_SD folder or an actual physical SD Card?
Anyone get Exchange with SSL to work yet? I'm hoping this ROM isn't plagued with LOS like sbrissen's is. Exchange and reliable data/text/calling is all I ask for. :)
I think you're asking for a bit much at this stage in the game. We're lucky anything works.
Can Android do a server-side search of your Exchange email? I use Touchdown. I got it back in the days when it was pretty cheap. It's a weird program, puzzling UI, but it can do a lot of things built-in clients can't.
Status
Lilrose
