[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
Re: [ROM][PORT][JB][07/30/12]CyanogenMod 10 [BETA 1]
Root access? I didnt touch superuser or the binary.
Yeah man root access no more, along with fc in storage settings, non working gps on 3g, still the issue with google now fcing when clicking im in, torch is broken, camera is broken(gallery not responding) im still checking...
i flashed this and now i get a blue light with a black screen what is up with this one ?
Titanium backup reboots phone when opening on beta 1
Sent from my SPH-D710 using Android Central Forums
Relatively sure everything that requires root does. At least that's been my experience.
unfortunately your beta works less then your alpha 4 with the media.xml
Tell us exactly, step by step, what you did.
He's bricked...good to know what he did though.
Either way, phone now needs replacing.
i downloaded the file via wifi direct to my phone then moved from my downloads to folder on my sd card flashed it and it stayed stuck on updating for like 10 min then turned off and just the blue light .......and fyi i can read thank you and tried to follow the instructions but it was my error so whatever now i have no phone..........risk you take right :'(
Yea. That goes without saying. I just wanna confirm if he DIDNT follow directions so I still feel safe flashing this thing.
As long as you flash in an EL26 CWM you're fine. Though I hold no responsibility if you brick...
dk any ideas about the working stuff in alpha 4 vs the broken stuff in beta 1? are you thinking beta 2 is needed?
no root access after flashing.Its says Sorry this device does not have proper root access. any idea .
would anybody happen to know why es file explorer doesn't work, thanks in advance.
i can see superuser installed but can not update binary in beta 1. Thanks let me look for lowrider 5.4.
Status
gaganprasad
