[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
Re: [ROM][Jellybean][08/02/12]CyanogenMod 10 [Beta 3]
So now Dark Knight has provided us with the most stable JellyBean build we can have until the Kernel is fixed. May not be a daily, but use it for fun for the time being :)
Before all the trolling starts... I just wanted to reach out and let you know that I would be more than happy for you to join us. Come by #jb-dev-e4gt on Freenode. We can compare notes :p
settings-> battery causes a reboot sometimes
EDIT: working, must have been a hickup
Negative ghostrider. Ill add my latest code to git when I get time. Anyone can pull from it. As ive said i am not a developer.
Everything works great, battery life isn't bad at all.
Only 1 bug for me, and that's wake lock. But even with it, the battery life is still decent.
spoke to soon lol. My first call worked now i cannot make calls and after a few texts i can no longer send texts. Not complaining just reporting.
as with cm9, can we flash new versions of cm10 on top of the previous or do we need to wipe each time as with a fresh install?
Ahhh thanks sosovoo it may be cause I didn't flash the latest low rider gapps 5.4.1. Downloading now then reflashing fingers crossed!
added a battery tweak to the buil.prop
made to put phone into deep sleep and seems to work for me. just adb pull the build prop and add the text to the bottom, save and replace it with the old build.prop, then reboot . or just edit straight from your phone through root explorer (es file explorer), save and reboot
battery tweak
#Battery Life ro.ril.disable.power.collapse=1 pm.sleep_mode=1 wifi.supplicant_scan_interval=150
I'm on low rider gapps 5.4.1 and beta 3
So far no issues at all lol
Still testing.
Sent from my SPH-D710 using Tapatalk 2
No issues at all? Including LOS, random screen ons, and wakelocks? Sounds too good to be true!
battery tweak
here is a pic for proof
Man, so far the Beta 3 is Beta smooth, or butta smooth which ever way so far, its going good, keep up that good work Dark_Night2
Los yes screen wakes not yet but im going to do the tweak just posted. The only issues I ran into so far is camera video after it records gallery crashes and causes the camera to freeze. Then a gallery not responding message appears.. other than that yea no issues :P
I'm so happy that annoying voicemail prompt is gone. You killed it again Dark :)
ok everything working fine now thanks again...might want to remind everyone to get the latest lowrider gapps also. ;)
Status
Dave7
