[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
Re: [ROM][Jellybean][08/02/12]CyanogenMod 10 [Beta 3]
Perfect pictures here as well. But then again it may just be because i am taking pictures of myself.
Reactions: patrao_n
Los yes screen wakes not yet but im going to do the tweak just posted. The only issues I ran into so far is camera video after it records gallery crashes and causes the camera to freeze. Then a gallery not responding message appears.. other than that yea no issues :P
I'm so happy that annoying voicemail prompt is gone. You killed it again Dark :)
Sent from my SPH-D710 using Tapatalk 2
i also have settings->developer options->checking "dont keep activities" and setting background process limit to 1. do this after the tweak
Reactions: NewWorldOrphan9
Just so everyone is aware. If you set the processes amount in developer options once you do a reboot that setting will not stick after a reboot. THIS IS A GOOGLE THING. NOT A GLITCH IN ANYWAY SHAPE OR FORM. im running ff18 and that setting doesnt stick after a reboot.
can i flash the EL26 kernel without Odin or Mobile Odin? is there a way to do it with CWM possibly?
is this close to being complete or are you going to keep going into like Beta 36 or something lol (this is just a curious question dont take personal)
added a battery tweak to the buil.prop
made to put phone into deep sleep and seems to work for me. just adb pull the build prop and add the text to the bottom, save and replace it with the old build.prop, then reboot . or just edit straight from your phone through root explorer (es file explorer), save and reboot
battery tweak
#Battery Life ro.ril.disable.power.collapse=1 pm.sleep_mode=1 wifi.supplicant_scan_interval=150
Applied and testing... thanks again
When Beta 4 is released can you flash it over beta 3 without going back into EL29? thanks :cool:
I've been stalking this thread for awhile now but finally got around to register.
This is built from source now? Yay :)
But anyways, I'm getting my new SD card tomorrow so I'll give you some logcats and last_kmsgs then hopefully. Does this still have the internal SD brick?
Things are sooo much better on Beta3. Thanks Dark_Knight2 for doing this.
I flashed B1 and 2 through internal with no issues other than the obvious. I think I might transfer it to the external this time around.
Sent from my EPIC 4G Touch!
Status
Michael Carvalho
