[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
Re: [ROM][Jellybean][08/02/12]CyanogenMod 10 [Beta 3]
The quick fix for battery that I posted has mixed results. This helps with the battery but by no means solves it completely. Some will see some success, some wont see it at all.
Dark_knight2, for me, deep sleep is only achieved when I am connected to a wifi network. So i think my tweak may be good for wifi connection
im thinking about giving cm10 a try.,.... i know last time the sound wasnt working when i got calls... and the vibration is weak... is that fixed?
The radio layer interface is still a WIP
Is there anyway we can help with the radio interface specifically? Certain logs, or something. If that was fixed in beta 4 or 5, this would be my daily driver! Other than the fact that I could ONLY make a call withing 5 mins of startup, the rom is smooooooth.
Granted I can only have this flashed for about 30 mins at a time, since I can't really walk out of the house with no service
go to the market and install signal speed booster. run app, which helps prevent los for a bit.
if coming from beta 2 do I need to reflash el26 kernel and wipe?
After about an hour LOS was bad I'm back on my old daily till the Los issue is resolved. Almost ready for a daily rom. Battery improved but still drains.
Overall I had better usage results with low rider gaps 5.4.1 over dk gapps. Everything ran smoother.
Keep up the good work DK2
Sent from my SPH-D710 using Tapatalk 2
I would like to know also.
Just FTR: If I flash EL26CWM in the built-in CWM6 recovery, does the el26 kernel immediately become active(so I can flash again safely)? Or do I have to flash it then somehow reboot recovery for it to become active?
Sent from my SPH-D710 using Android Central Forums
Why cant i get access to my External SD through the file managers
Weird I have never experienced los in any builds ever
5 hours time % w out signal is at 0%
I followed all the steps, one by one, everything seems fine except for SMS, can't send, it fails. Thoughts?
Also, when I connect the phone to my PC, the external USB won't load. Maybe this is a known issue, my apologies if that's the case.
Thanks
[update]
I was on FE22, just updated to FF18 and now SMS works! external card is still not loading though.
Status
avromo
