- Jun 24, 2012
- 1,716
- 1,432
- 0
Weird I have never experienced los in any builds ever
5 hours time % w out signal is at 0%
Really? That is weird [deleted]
gallery not working in beta 3 it wont load all files from the memory and also the auto rotation is not working
Lol. I went onto xda and found an alpha build of cm10. Lol. He called this rom "Just a port" and funny thing is that beta3 was built from xboxfanjs cm10 git. And merged with sbrissens device tree. Yup this is "Just a port" :thumbup:![]()
No offense but the people who worked on that from source are more skilled than you. And chris41g has worked miracles over at XDA and yes this is a port for the most part as you have said yourself. That alpha build is from source. So do. Or laugh at something you cannot do.
Sent from my SPH-D710 using Tapatalk 2
I need help before I brick guys
I am on AOKP and I have the safe clockwork recovery 6 if I want to flash this would it be ok if I flash from this ics rom with this recovery or do I have to use the el26?
THANKS!![]()
THANKS!![]()
You want to play it safe and Odin el26 CWM kernel then go from there.
No I am not. He laughed that they called it a port. Well at that time it was at beta 2 which it is a port yeah it has some stuff that is from source but a port is a port. Not completely built from source like the one over at XDA. Great job to Dark Knight for doing this.
By all means try to blooms.
I have never jumped in on any beef scenario. But in this case, who cares how anything is built. If you make roms for my phone that's all I care about. And if it is to get the next best system update before the manufacturer releases it (if they were planning on it, which i doubt.), then i am all about that. Good look OP.
Sent from my SPH-D710 using Android Central Forums
