[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
Re: [ROM][PORT][JB][07/30/12]CyanogenMod 10 [Alpha 3]
Confirmed mms fixed, apollo is the issue power amp works fine, most settings work now. Still cannot get google now to cooperate fully ( Can anyone confirm voice output still broken?)
cannot believe torch works out of the gate!
Reactions: Dark_Knight2
I updated my op with what is working and not working. Making great progress. Next build should meet Beta Stage. Alpha 3 should be stable enough as a daily driver for some folks.
Any possible ideas on how to fix YouTube its a daily for me when that's fixed...
Sent from my SPH-D710 using Xparent ICS Tapatalk 2
terminal fc's, alogcat will not work. Any ideas I will post a logcat tell me another way.
Hey I have a logcat running how do I get it to save to a txt or something so i can upload it?
Poweramp gives me the same error as Apollo so it's not just an Apollo issue, there is something else there.
Edit: nm must just be my phone then.
Sent from my SPH-D710 using Android Central Forums
Dark knight you have any idea how to get YouTube to work??
Damn power amp don't work either ): I was about to flash too but I use power amp everyday on the train ride back and forth to work, will wait for the next release
Sent from my SPH-D710 using Tapatalk 2
No it's just me apparently, poweramp seems to do the trick for everyone.
Status
jades
