[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
Re: [ROM][PORT][JB][07/30/12]CyanogenMod 10 [Alpha 3]
quick question, i flashed cwm6 wipe data, cache, and davick cache, flashed rom, my phone turns off, try to power it on and only a solid blue light appears and nothing comes up, phone appears to be bricked, anyway to get out of this.....phone appears to be non-functional
pull battery try again.
possibly also not enough charge to the battery?
You didnt follow my directions in the OP :thumbdown::rolleyes:
Move ROM and Gapps to SD Card (If you dont do this you WILL BRICK)
Did you miss that?
Did you miss that?
Dang. What the heck ? Lol why does that brick the phone ?
Sent from my SPH-D710 using Android Central Forums
I think the only reason Google voice don't talk back is cause no sound works except music from poweramp ringtones don't work when I get call it only vibrates messages nothing just notification in status bar but I think once sounds work Google will work it hears you flawlessly:):)
Sent from my SPH-D710 using Xparent ICS Tapatalk 2
Reactions: Dark_Knight2
Did you miss that?
I've flashed yours and sbrissens build both through internal without any hiccups. My steps that have worked are flash EL26 CWM I posted above first then wipe all script from calkulin, then your ported CM10 then gapps.
ha didnt notice that, wonder why I never saw that i had messages
I can't get google now to work at all, keeps force closing once I set it up.
It works for me. I chose Not Now when I initially started it
Reactions: Beejis
DK2 did you also see in the logcat that the screen isnt staying asleep when you hit the power button it turns off the screen but a couple seconds later it comes back on. If you didnt see that I can post another logcat showing a couple of different times it awakes.
I'll try that out when I flash the next build (Alpha 4). Thanks for the suggestion!
You were supposed to hit no maybe later when initially selecting Google now.. try reflashing clean of course and when initially going into Google search hit no maybe later all should be good
Reactions: Beejis
On alpha 3 data/3g is in and out for me anyone else?
3g works for me, the only way google voice search works again after clicking enable is to go into settings and factory reset, or data reset in cwm. I did it on purpose so it would show on the log for dk2 though.
OK. So which kernel/recovery is more recommended, El26-CWM or Chris41Gs RC2_5 CWM6?
Great question. I've only known folks brick on CW6 over at xda but the OP probably is best at answering this question.
Status
ellahayes
