[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
OK FYI I'm posting CM10_RC1_20120805_Release-keys.zip thats found on the OP on my http site for anyone who has trouble dl from the Original
Feel free to dl as much as you want. JB Gapps is also there.
Download from the link below:
HFS /public/
Thank you for the link, bu tmy question is for every update do I have to flash back to el29 and reflash new update?
I just tried to flash cm10 from a non el26 or 29 kernel and it did not work.. so to be on the safe side i would say yes, flash back to el26 and go from there... its a pain but at least we know it works.
So I can't use EL29? with cwm mod?
Sibressens kernels recovery is safe as can be. Have flashed many a rs and nandroids with it.
Sent from my awesomely EPIC Phone
HFS /public/
This server is wicked, and i maxed my 35 mbps download speed on dl one file off ur server
Sent from my SPH-D710 using Tapatalk 2
Reactions: deakelem
I'm not sure to be honest i never tried from el29 I just know that the OP says el26 so you might wanna try that. I flahed from ff18 and i didnt brick but i had boot loops. I was able to get to recovery and to download mode.
This server is wicked, and i maxed my 35 mbps download speed on off dl one file off ur server
Awesome man thanks, its good to hear lol. I'm looking right now and I got about 11 people dl at the same time so Im glad its holding up.
Reactions: patrao_n
I'm using EL29 with CWM5.. no issues out of the ordinary. I download the latest posted CM10, use Mobile Odin to flash my EL29 kernel, pull the battery before reboot, wipe flash and repeat for the next update. No computer, just me and JB on the run thanks to DK's hard work :D
Whats the easiest way to keep up to date with CM 10 updates?
No worries, it still puzzles me that everyone seems to be having wakelock/or LOS .I have no issues ( except for the one mms issue I fixed do to my error). I can switch between wifi and 3g and be perfectly fine, in fact the bars and everything seem to be working flawlessly. Deep sleep as soon as i hit the power button and absolutely no waking up unless I want it to. No LOS when charging, and no random reboots. Torch, camera, gps, wifi, 3g, mms, sms, calls, no los, deep sleeps, google now, bluetooth(except for media), marketplace, battery life, etc etc all normal. ::shrug::
What gapps are you using?
Sent from my SPH-D710 using Android Central Forums
Running this with US Cellular and have not had any issues in regards to losing service. Everything seems to run fine on my end except for the phone running hot. Can't really complain as most 4.0+ roms cause my phone to run warm.
Awesome news buddy!
Ugh, I don't know what happened. This afternoon everything was perfect, now I *NEVER* go to deep sleep, and RILJ always has a wakelock at 1200 (or 800 since I have my CPU down). I get near constant LOS now, rebooting doesn't help. The only apps I installed were Apex, SetCPU, BetterBatteryStats, and a few apps like Feedr and Reddit. Everything was functioning fine at noon. :/
have you changed your location?
Status
witnessloc03
