ARCHIVED: [ROM+Kernel] ~*~ Bumblebee 2.4 ~*~ (6/25/2011)
Status
Not open for further replies.
I think there may be an issue with my cell radio. I am losing signal all the time or it switches to 1x. my friend has the same phone/rom and has no issues. should I restore stock and go to the sprint store as they sell VM phones there. not sure what else to do cause I am getting tired of all the dropped calls. I have done a full wipe many times I have the same issue no matter what rom I use.
Let us know how it goes, because once you root your phone the warranty is supposed to be voided.
Found it. Now to nandroid flash lg recovery then unroot and i should be good. Hopefully i can get a replacement cause ive only had this phone for like 4 months.
I think after 90 days or similar you need to contact LG. But, going into a Sprint store can't hurt. They may just hand you a new phone. Let us know how it goes.
I thought Android 2.2 supports installing apps to SD? The "Move to SD" under Application is not available so I presume still need to create EXT partition and use Link2SD or similar? A bit confused so any help will be highly appreciated.
2.2 does support Apps to SD, but not all apps support it.
Just to let everyone know I'm still hard at work on big things to come. Right now I'm testing a new kernel built from the Android msm-kernel source updated to the newest kernel. This has been a much bigger project than I first thought, because I'm having to isolate every change LG made to the old kernel for the V's hardware, and incorporate those changes into the new source (which is sometimes drastically different). I've still got a lot of testing to do, but when it's ready it'll be worth it. This new kernel will set the stage for Bumblebee Gingerbread. :D
Reactions: ejlmd and Jsadik
Awesome I defently want to test that out when its ready. Thanks for the update.
^^ That's great!
Has Gingerbread been released for the OV yet, or are you planning on making it work on the OV yourself?
^^ That's great!
No, it hasn't been released, and I'm not holding my breath for an official VM Gingerbread for this phone. So, I'm building my own from the Android Gingerbread source. This is not CM7, it's pure Gingerbread. I've still got a lot of work to do on it, so I can't make any time estimates, but so far I don't think there are any permanent road-blocs.
Reactions: ejlmd
please dont break the camera and phone apps like cm7. please please please
Status
layahhhh
