[ROM+Kernel][CM-11.0][4.4.4][OS2SD/internal][f2fs]bigsuperROM-thunderc-4.4.4
Re: [ROM+Kernel][CM-11.0][4.4.4][OS2SD/internal]bigsuperROM-thunderc-4.4.3
7c45f20212270bc988094fb2c1ca92ff local, 42d4ea5f28a61a2f3537fbb15a137b42 posted for the 6/23 OS2SD. Sorry, man. Thanks for your hard work. Drive is being a PITA, it seems.
Sure enough. I get same md5 on download. Deleted and reuploading... slightly newer build since I File-13 most everything I don't upload.
Thanks y'all for pointing out the glitches. I test before upload but only download to test if problems are reported. Those md5's are an excellent safeguard.
Boo, Google Drive.
Or, boo user error on my end, maybe needs make installclean more often or something.
Can you upload it to dropbox or mega instead of google drive?
I can barely connect to it. Sloooow.
Uploaded os2sd from today.
Nifty new feature: CMAccount allows flashing GApps immediately with ROM.
Including CMAccount in new internal for same function.
You MUST use the new TWRP for this one. And no dirty flashing.
I rearranged partitions... 2nd is either sd-ext or swap (your choice in partitioner), 3rd still /system, 4th /data.
/cache is internal.
If you have already partitioned for os2sd it'll still work. But /data moved.
If you want a dirty flash:
in the old twrp, mount os2sd data and wipe dalvik-cache.
then advanced backup your /data in the old twrp, and then flash the new twrp.
reboot recovery. wipe system and data, restore your /data.
install the rom then gapps, reboot.
I'll get to the carrier fixes with maybe a surprise later.
/cache is internal.
Going to do a clean flash tonight, hope I get lucky :-$
How do we install this? It downloads as an html file.
Sent from my LG-VM670 using AC Forums mobile app
open the link, don't download it. is a web page.
I try not to hotlink other people's files.
Re: [ROM+Kernel][CM-11.0][4.4.2]OV-KitKat (JBC based)
updated carrier fixes to 4.4.4 including internal versions.
need tested.
Latest internal build is nor charging. Recerted back to previous working build and charging works. Tried to redownload and reinstall and same thing. It doesn"t even recognize the xharger. Otherwise? I love this build.
Sent from my ZombieKat 4.4.2-VM670 using Xparent Skyblue Tapatalk 2
2nd report of charging problems.
Try flashing the kernel zip from its thread.
bah, quick releases+me pondering and piddling around = you not getting to dirty flash until the instabilities on partitions settle down.
partition 2 should remain ext4 for internal, of course, to not mess up 2sd methods, whether Toucan's or other.
partition 3 for internal will be swap, because it does seem to help the old workhorse.
There will be a special new TWRP soon for you diehards with internal installs. Allow partitioning p2 ext4 and p3 as swap, which is default for TWRP now anyway. (well, they select between ext3 and ext4 for p2)
OS2SD will remain p2 swap/ext, p3 system, p4 data.
Why are the partitions having instabilities?
Tried flashing the hernel, but no luck.
Charging will be addressed in next build.
Source changing constantly on my end last couple days.
Hmladlossau
