[ROM+Kernel] Inferior Human Organs unofficial CM7.1
Click on widget layout in lockscreen settings/widget options. This is running the mirage build.
Well that would explain it, I'm using backside. Gonna try mirage build now. Thanks :)
I an posting this in case others are having this issue with the preinstall Darktremor Apps2SD on the BobZhome ROM...
I was using BobZhome's 8/30 version and enjoyed the great space that Darktremor Apps2SD gave me... Unfortunately when I switched to the 9/13 version (and all newer versions) Darktremor no longer can move the Dalvik-Cache, the phone freezes on the second LG Logo during reboot (pulling the battery was the only option)... When finally booted up the operation didn't complete... Even running repair did not work. I attempted to even perform the operation manually while in recovery... And the same thing happens...
However I did find a solution, reinstalling Darktremor worked... Works now like it did before...
The one I installed I found here: http://www.darktremor.info/files/a2sd/dtapps2sd-2.7.5.3-beta02-signed.zip
Hoping this helps others...
Sent from my LG Optimus-V using Tapatalk
Reactions: DF3 and BobZhome
My fav is the baseband, that's an actual picture of Saturn with the sun behind it taken by the Cassini space probe. Awesome!
so, out of curiosity, has anyone updated the IHO recovery on the wiki since BobZhome fixed the kernel screen driver issue? I'd like to link to the authentic recovery in the blackscreen thread, instead of just the two versions I've patched with other kernels (although it is nice to be able to use PST's in recovery with the stock recovery kernel, since the IHO kernel doesn't play nice with any PST I've tried)
Thanks for the info.
Wish the new backside had mirage's lockscreen. Think I like it too much to give it up. Battery life was better on backside though.
Thanks. I'll have to give that a try. When I switched to a new version the apps I restored through Titanium Backup weren't moving to the sd-ext partition despite claiming to work when doing a2sd check through terminal. I was however able to get them to move with Link2SD.
Does 12% per hour battery life use sound about right for moderate use? I'm using min 480 Max 806 CPU with interactivex governor and mirrage build...what should I be getting?
In the green machine theme, looks like the shadow on the vibrate button needs a 90? CC rotation. Unless it's supposed to be like that?
I'm getting better battery life than that. 14 hours with 16% battery left. And that was very heavy use over wifi surfing, playing games, reading on my kindle app almost continuously.
I have synced with CM and uploaded the 09282011 build.
Main changes:
- Minor updates to ring lock screen widget (see details here)
- it is now possible to override connection settings (WiFi, Bluetooth, GPS) in the profiles. (see Settings -> Profiles)
Do not use the previous transparency theme file. You can also find the new theme file in the Wiki.
For the link2sd problems, refer to my previous post for 09262011 build.
As always, thanks to Blarf, Bob, Jerry, and CM team.
Reactions: mustafu
What settings are you using? It could be because I'm using 3g with pretty low signal
I manually turn on and off what I need. If I don't need it, its turned off. CPU set to 480-748 on demand. On an average day I take it off charge in the morning still am at about 35-40% with moderate usage. That is about 16-18 hours. The day in the screen shot I was trying to kill the battery to see just how long it would last with heavy use.
I've been running Backside for a while, I really like it, and I appreciate the work that went into this, it's truly amazing. However, the lack of a working headset button is driving me crazy! Do any of the IHO Roms support the headset button? Is this a really difficult fix? I would go back to a Froyo Rom, but I know I would miss some of the IHO features. Forgive my ignorance, but does anyone have an answer/update for this problem?
No update so I'll assume it's hard to fix. Lol
nemismom
