You could download it from your phones browser and then move it to the root of your SD with a file manager. I've done that before.
Ok thank you. I will try that.
You have Google Wallet after upgrading? I don't.
\\Yup, I reported the same issue a week back. Did a fresh install/wipe/all that jazz and still no MMS. So I'm back on bumblebee.
Edit: My bad, it was actually BACKside that I was using but this seems a recurring theme.
I actually haven't flashed the latest build yet but I remember hearing about Google Wallet on Android 2.3.7 and cyanogenmod being updated to 2.3.7 so I figured it was in there.
I wish I could get on Bumblebee...every Rom I try randomly reboots and freezes. I hate this phone. It was fine before the screen update.
place blarfs recovery on the root of youre sd card rename it something simple like bob then go into terminal emulator and type this, flash_image recovery /sdcard/bob.img
what happen if you install blarf's recovery over cwm recovery? Do i loose my backups?
I tested sending and receiving pictures with my daughters phone, which is on MetroPCS, and it worked both ways.
Bob
I have had the same problem (posted this a few pages back, I think). There is an easier solution, but you need an adb shell. You can get into the shell during recovery or while the android is spinning:
mount -o remount,rw /system
chmod 640 /system/etc/init.d/01mvdalvik
mount -o remount,ro /system
a2sd cachesd
reboot
You really don't need the 2nd mount command, so if you are a lazy typist, you can skip it.
The comments on the bobzhome page say something about swap being enabled or working, but in fact it looks like there is no swap support in the kernel. Anyone know if that's true or am I having operator error? Not sure I'd really want to run with swap anyway, but would like to know if I'm doing something wrong.
Great ROM.
The 01mvdalvik cache moves the dalvik cache to the cache partition if you clear the cache.
My Dev tools opens with out crashing.I wiped everything and re-isntalled your 092911 build for LG Optimus [V] and it still refuses to send MMS messages. If you go into Dev Tools and you try to enable MMS, Dev Tools will crash so there is definitely something wrong here. Also on the MiRAGE build the MMS is working fine.
I am obsessed with your build because youre the only one that fixed the accelerometer by reverting back the device sensor in your previous build.
