I can confirm this as well, when you try to install from the web based market, the popup appears asking you to choose your device, and when you try to select it a floating popup appears saying it cannot be installed in your country.
Ok, so it appears you're having the same problem I am. Nascar, which build are you running? I am running the latest Jerryscript build (7/25)
Can anyone else confirm if they have the same problem: On your desktop computer, go to http://market.android.com and try to install an app. Does it work for you?
One thing I noticed: If I go to https://market.android.com/account , then click on the Settings tab, it displays an empty field under 'Carrier'. Could this be a symptom of problem?
(And, is this market problem just with this build or with all CM7 builds?)
Is there anyway you guys can optimize the keyboard it just doesn't seem as fast as froyo
Sent from my Optimus V
This is a longshot, but is it possible there is something in the build.prop file that is misidentifying the phone?I can confirm this as well, when you try to install from the web based market, the popup appears asking you to choose your device, and when you try to select it a floating popup appears saying it cannot be installed in your country.
I noticed this too. The keyboard feels a tad slow. It's just a little slower, but definitely enough to notice it.
is anyone else having random freezes?? idk maybe its just me ,, just wanted to know bout you guys
I ws hving trouble with the xioni recovery, things not going on wy from previous flash. Switched to clockwork recovery and haven't had issues since. First time xionia ever failed me![]()
I'm using the BACKside 7/25 build, and I replaced the build.prop with one from a previous installation in order to get Swype working. The build.prop has been sitting on my SD card for a couple weeks, so I'm not completely certain where it came from--but I wanna say it was from one of the ath3nos builds, before Jerry started the BACKside distro of IHO. Anyway, installing OTA from the web still works for me. I just successfully installed Fruit Ninja.This is a longshot, but is it possible there is something in the build.prop file that is misidentifying the phone?
I tried the fix in this thread but it didn't help.
