[ROM+Kernel] Inferior Human Organs unofficial CM7.1
I agree with you but atleast its not like the aospcmod disaster 6 months ago
But there is the potential for it to be like that dissaster since we don't know the origin of the files posted there.
I'm trying to turn over a new leaf in regards to RM, but I still have 120 hours of wasted life helping people who bricked their phones with RM, so it's not easy to forgive and forget. Especially since koush doesn't help or take any responsibility for his paid app!
I remember, I had instructions on how to flash recovery images copied on my phone so i could just paste it everytime people asked.
Does anyone know how to use wired tether? I'm using Jerry's 11/22 build and when I try to turn wired tethering on, it says it's on for about a second then it turns off.
I think the new kernel in recent roms does have poorer battery life.
Something wasn't installed right. Check the md5 value of the downloaded ROM zip file, be sure it matches the posted value.
1- Reboot into recovery
2- Wipe cache, and under advanced wipe dalvik cache
3- Format boot, system, data, and cache
4- Flash the ROM zip file
5- Flash gapps
6- Reboot
It should take about 4 1/2 to 5 minutes to fully boot the first time.
Thanks, the extra step of formatting the boot, system, data and cache fixed it.
I use EasyTether from the market. It is a paid app, but I find it is worth it. Install the app on your phone and follow the setup instructions. You will have to install the Easy Tether software on you PC or laptop. I don't use it that often, but it does work so much better than wifi tethering and also allows you to charge while surfing.
Did anyone else lose headset button functionality on Jerry's 11/22 build? It was working fine on my old build (I skipped a few updates) and when I updated to 11/22 it stopped working, but everything else is great. Maybe I just need to reflash and try again?
I also don't have headset controls with BACKside 11-22. Jerry posted a link to a flashable fix for it but it didn't work. I flashed it and i still don't have headset control.
Tapatalk via iPod touch
Google Goggles works fine for me as well, though I downloaded it originally when signing in to gapps, it's one of the apps you can choose when setting up the market install for the first time.
I would say do a complete wipe (cache and dalvik, a complete format (boot, system, data, cache), then flash the ROM and gapps. Do NOT restore any apps or data till you have tested out the issue. If everything works, reinstall a few apps, then test again, repeat till you find an issue, or have everything restored with no issues.
If you have troubles after this, report here and we will try to help. ;)
Fixed!
Must have been a bad flash or something...
Reactions: JerryScript
Also, which apk matches up with the "Video" option in the ADW Launcher drawer? I'm trying to remove some of the non-essentials but I don't wanna delete the wrong thing lol
The video icon launches an intent to the video player, with a special key to display a list of video files.
Reactions: jdcnosse
My phone will not mount usb at work, but works at home. It used to work with the stock rom.
I take it that the LG drivers need to be installed?
No, just put the phone in recovery then go to to mount and go to to mount USB storage
JERRY!! when is the next update >.<
As soon as I have time to work out a small bug. I've been reorganizing my repository instead of just syncing with Blarf's. Git is a pita, so I'm taking it one or two commits at a time, building between each to insure there aren't any lingering issues with my setup. I normally post new builds on Mondays, this time it looks like I'll be done testing on Wed, if I'm lucky. ;)
Reactions: cr42ydude
This was my first thought, but it didn't work.
Are you using the same usb cable at both places? USB cables are not all built the same, some have 3 wires, some have 6, some have 8. Those with fewer wires often don't have the 5v lead.
Xpornefar
