Yes!!! A new build!
I was having withdrawals... xD
I needed to flash or do something to my phone sooo bad!
I can't take screenshots by holding down the power button.
Flashed it a few hours and I gotta say that I freakin' love this ROM. The other one I tried was MiRaGe and it was buggy (rebooting even though there wasn't much RAM being taken up). BACKside is a score, the fellas who developed this constructed it very well. Can't wait to see what turns out when the CM devs finally get ahold of ICS source. I expect a great CM porting to the OV by the BACKside crew when they release the 4.0 code. Loving it guys, you did well.
ooh ooh. So question.
Is there a way to retain/backup my settings to apps that get reflashed when I update IHO?
For instance, all the settings in my stock Messaging app get reset back to default.
Are you sure you're following the directions for updating and not flashing from a new ROM? because when I update, all my settings are still there
With the 12-7 build of backside I get no audio on my videos about half the time. Should I just delete those ogg files? If so, where are they located again? I forget where they were. Or can I just turn off shutter sounds in the CyanogenMod settings to fix it?
Sent via VM670
Battery life after the first day of use of your newest build Jerry- just wanted to put this out there for people worried about battery life on this ROM- I get better then stock. Don't ask how my battery went up without charging; Backside must unlock the secret reserve battery hidden in the Optimus V when the battery gets low, lol.
Tapatalkin it from my IHO CM7.1'd, ICS Themed Optimus V
