It happens in all my apps.
480min/768max
And I use the stock keyboard.
I am downloading the new build now.
Which governor?
480min/768max
I spent the better part of three hours getting this update installed...
Data2ext was throwing all kinds of errors if you flashed the zip before doing the adb commands.
If you did a backup via TB or MBP restore that first. There is some sort of weird bug that isnt restoring apps fully. I bet they are there just hiding waiting for you to turn the light switch on so they can jump out and yell surprise!
Which governor?
My battery life is horrific with this ROM, 20% in 30 minutes. got Setcpu with screen off prifile at 122-245 and normal at 122-600, charging is even really slow. I really love this rom, but im going to go back to bumblebee until the battery life gets better, I understand its a problem with basically all the cyanmod roms
On demand and interactive.
I tried the SA governor and I don't like it. This build seems faster but its hard to say I switched to Bumblebee Rom for the last 2 builds.
What errors?
This may be a dumb question, but is there a difference between Jerry's build and Kemikal's build?
so should i go and flash the newest 7/27 or just stick with 7/25??
There should be another build soon with more commits today to kernel r2. So I would hold off for a bit. See what Jerry says.
Where can we find Kemikal's build?
