[ROM+Kernel] Inferior Human Organs unofficial CM7.1
Unused RAM in Android is wasted RAM. In some situations it can speed up loading of new apps, that's probably where the speed boost comes from. For most people, it's more preferable to use the RAM to cache apps in the background so you don't have to reload them every time, it defeats the purpose of a multitasking OS.
Correct, which is why its annoying me IHO clips apps around 250-230MB of free ram. I have tons of ram left but it simply will not keeps applications open.
To compare I can get Froyo to respect minfree values but IHO does what it wants in that regard.
Hey guys in extremely new to flashing roms. I succesfully flashed this rom after 3 failed attempts were it would get stuck in the boot animation. The thing i did differently this time was i did not flash the bootsound and green machine theme. The realizing that i forgot about it i went back to flash it. Then once again i got stuck in the boot animation (Which btw is really cool with the bootsound). I think i am flashing in the wrong order or there is a problem with something i'm doing. Plzz help, Thx in advance
It seems that the latest BACKside has a flaw with the integrated boot screen changer, everything worked fine until then, now i have to reboot into recovery and re-flash cause my phone is stuck in the particle boot screen after i changed it with that integrated boot screen changer.
i dont get im a real newb ,where do i fiind a mod and kernal that works with my optimus v ..ive downloaded rom manager , flashed my current rom ,booted into recovery mode and pushed back up ...then what, am i missing something ?
Is this confirmed?
Read the first couple posts in this thread
IHO Unofficial CM7. 2
BACKside IHO 12212011
Nope, it works fine, so long as you have the default file manager installed
I have been using your IHO for a long while now and never had this problem, I dont know why it did, maybe I did it wrong, but I ain't going to risk doing that again-- if I want to change it I'll just change it manually.
Just to confirm, since I too removed the OI Filemanger--all I have to do is reinstall from the market, move the apk back to:
Code:
/system/app
rename it to Filemanger.apk and the update will find everything it expects to find?
Or has the OI Filemanger been tweaked to fit the system and I need to get the one from the rom?
Also, what is the impact if I removed ADW Launcher?
I've never updated with the application before so I want to do it right the first time if I can.
Code:
/system/app
I don't know, I use the default apps (fille manager, launcher). I build to support them, it's almost impossible to support other file managers unless they follow open intents like the incliuded OI File Manager.
Are there any plans to use patch files instead of a full update? I knwo companies like htc use them and it cuts down on update zip size as well as reduces the need to wipe data. I found something a while back on it and it seemed easy enough
Code:
/system/app
I've removed adw and replaced it with go launcher with no problems yet other then every time I update to the latest build I have to do it again.
these updates just keep getting better and better. I haven't converted over to one other ROM since Sept.2011!!! I was just wondering in one of the future updates. can you make it so that we can change the color of the "battery" and the "wifi" icons?? or is there even anything out there for that already??
Reactions: JerryScript
Awhile back I put in a feature request, but when I typed it I was tired and it made absolutely no sense. It was for Jerry's ROM. Now that I'm not so tired, I was wondering if there is any way the notification switch mod from this XDA thread by Taine0 could somehow be implemented into the ROM. Something like the center clock, but with the notifications instead. It would be awesome if it could be, but no biggie if not.
Tht would be cool, but you can do that by editting the pngs in a paint program and placing them back in their reapective apks... to get something like this.
I'm wondering jerry, if you can do sonething in some xml to add like a color filter over each app in order to accomplish what he wants, so then you cpuld change the filter.
Tneustemez
