New build of BACKside-IHO us up!
Download via the BacksideUpdater (just wait till you see the new one!)
or
BACKside-IHO-VM670-04172012.zip
md5sum d396e9c3e62e80747f00877415ea6bb7
GreenMachineTheme-04172012.zip
Changes: Synced with CM and cherry-picked some changes
-- Lots of behind the scenes code improvements in dalvik, should lead to smoother performance
-- -- BacksideUpdater huge update!!!
-- -- Added download progress indicator but it is still OK to exit and let it complete in the background
-- -- Added the ability to Automatically Install ROM Updates!!
-- -- -- Once you have downloaded the ROM package and BacksideUpdater verifies it, you can select Install ROM Now and your phone will reboot and wipe cache/dalvik-cache and install the ROM and reboot back to normal All Automatically!
For the best results download and install CWM-Green-Recovery, a new recovery I built for just this purpose!
Note- Automatic install has been tested to work on CWM-Green, BobZhome, IHO, and Drew's-Touch recoveries. Automatic wipe dalvik-cache only works on CWM-Green-Recovery.
Thanks as always to Blarf, BobZhome, mrg666, tdm, LeslieAnn, gannon, tvall, Whyzor, bigsupersquid, kermikalelite, the CM team, the AOSP team, and a whole lot more!![]()
This is so awesome Jerry. Thank you for your awesome work.
Can you explain what automatic wipe dalvik cache does? Is that wiping the dcache from within the ROM like CM7?
Thanks!
Sent from my VM670 using Tapatalk 2
