[ROM+Kernel] Inferior Human Organs unofficial CM7.1
And why quickpic?
Give it a try and you'll see! I started using it on my NookColor (we have Gallery crashing issues too) and it blows Gallery away IMHO while performing faster and smoother.
Sent from my NookColor using Tapatalk
True. I also use the unlimited data of VM in the US. The VZW/PPC phone is only used as a backup and when I travel to Canada since there is no roaming in Canada with VM.
I always wondered why you have page plus and vm. Thanks for curing my curiosity (at first I said "pp" instead of page plus, bit it inapropriate so I changed it
Another alternative to Gallery and QuickPic is JustPictures (free in market).
It has high quality rendering, displays (and/or syncs) pictures from Picasa, Flickr and other online accounts, and has great metadata features (such as quickly show/hide metadata and optionally displaying a small map to show where photos were taken).
Once I installed JustPictures, I never looked back. Others may have other preferences.
Something that streams, or just a player? If you're looking for just a player, I highly recommend Poweramp.
yeah go poweramp.
Sent from your mom's phone.
New build of BACKside-IHO is up, and new CWM-Green-recovery too!
Download And Install viat the BacksideUpdater in your app drawer.
or
BACKside-IHO-VM670-05022012.zip
md5sum 066c2f984c612821e9b3584e1efbdba2
CWM-Green-recovery-05022012.zip
md5sum e3963b7709fe23c2ae5667e318e50d96
GreenMachineTheme-05022012.zip
Changes: Synced with CM and cherry-picked some changes
-- Default keyboard now has option to use volume keys to move the cursor
-- Added snooze times to Calendar alarm events
-- Contacts now have individual call histories
-- Added format option to T9Dialer
-- Fixed typo that prevented baseband from showing under Settings>>About Phone
---- BacksideUpdater Backup/Restore Options!!!
-- Added the ability to automatically backup
-- Added the ability to automatically restore (CWM compatible backups only)
-- Added option for full wipe and format before automatic installation
-- Added the ability to automatically install any ROM or Theme zip file
----Note: Automatic functions require CWM-Green-Recovery V3.3+
This should be one of the last updates to CWM-Green for a while. I may add touchscreen support at some time in the future, but the basic code seems pretty stable now.
Thanks as always to Blarf, BobZhome, mrg666, tdm, LeslieAnn, Whyzor, bigsupersquid, thekraven, the CM team, the AOSP team, and a whole lot more! ;)
or
My most favorite rom :D
or
Thanks for the birthday present :)
great updates. but what is up with mediafire and the page needing to be loaded twice on every download? every download i get from there as of late fails with the download not working? try again. message before it actually gives the file. :banghead:
I'm pretty sure that has happened everytime i've ever tried to download from mediafire from my phone. Just another of life's annoyances.
For those saying stuff about mediafire on phones... the solution is that when you load the download page, you long-press the "download" button and then select open. It will download right the first time if you do that. I think its something about mediafire redirecting mobile devices, but when you long press, it forces the URL of the download.
I have a problem and I don't feel like starting a whole thread when I might be at fault.
I live in upstate new York, outside of Albany. I am running BACKside right now since I'm working on cm7 themes, and all this evening, my signal has been dropping like crazy and 3G has been dropping to 1x all the time. I almost can't even use the internet on it. So I'm just wondering if its a problem with VM service and if anyone else is experiencing problems, or if I brought it upon myself and need to reflash.
Jerry..I just had a brilliant idea for the updater! Any way you could add a push notification when a build comes out? Or have it check once a day/week for updates then display a notification?
Toxxyroxy
